Biggest Cam?
Old Jul 13, 2004 | 09:58 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Biggest Cam?
Hey everyone i got a cam sitting in my garage and its going in this weekend. My question though...What is the Biggest cam they make for a 3.1? Mine says Duration 204/214. Is that a good thing?
Old Jul 13, 2004 | 10:10 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I do not know for sure the "biggest" but I have seen 216/216@110* 0.65/0.70 lift and required custom pistons.
THAT was a flowin' mother.
The one you have is a little over stock on exhaust.
Old Jul 13, 2004 | 10:17 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Actually, the one you have, for a 3.1, is a good step over stock. About 2 *steps* up. It's equal to the 3.4 cam.
Old Jul 13, 2004 | 10:34 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
......ummm, Doward, that's the cam duration you and I have isn't it??? YUP, And it isn't really a 3.4 cam, the 3.4 share basically the same cam as the 2.8/3.1. A STOCK 3.4L cam is: Int .263 - Exh .273 Dration is 195*i 201*e That cam will give you a very noticable gain. Might wanna upgrade a few valvetrain pieces too make sure things work properly. I JUST went through this song and dance, so if you have any questions, people will help.
Old Jul 14, 2004 | 12:39 AM
Doward's Avatar
You sure? I coulda swore the stock 3.4L cam was a CompuCam 2030 - 204/214... off to look....
2.8/3.1L Cam is a .373/.409" lift (remember, 1.5 rockers stock)
I can't seem to find any duration specifications, anywhere...
Old Jul 14, 2004 | 07:08 AM
oil pan 4's Avatar
Car: 89 Firebird
204*/214* is a small cam.
The biggest I have seen is a mechanical cam made by crane, it is not for street use.
My crane 2-272-H hydraluic has 216*/228* duration @ .050'' and .454"/.480" lift. and If I can get 1.6 rockers I can get .480"/.511" lift, and the springs I have can take it no problem.
My heads are stock (except for the P&P), I used springs, retainers and different valve locks to get them to take that lift.
Old Jul 15, 2004 | 02:43 PM
Engine: 383 Stroker
I plan on redoing the whole valve train so im not worried about the size of the cam being a problem. Is it going to sound lopey?
Old Jul 15, 2004 | 04:54 PM
oil pan 4's Avatar
Car: 89 Firebird
The lumpy sound is valve over lap where the intake and exhaust valve are open a little at the same time.
That 204*/214* won't have much if any over lap. It won't sound lumpy I don't think.
The crane 2-272-H cam only has 1 degree of over lap, all the meanness will come from the duration and that exhaust valve being open so long.
The smaller crane mechanical cam has like 4 or 6 dergrees of over lap, I saw a web site where a guy put that cam in his 3.4, there was a movie and that car sounded meaner than my Z28.
I said my heads are stock, there not I cut valve guides down a little like .020'' and now there .530'' wide insted of .64''
Old Jul 15, 2004 | 06:59 PM
FbodTrek's Avatar
Mine has a slight lope...... it's more lopey than before anyhow, sounds nice idleing with the cut-out open.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
