Freaking Lifters!!!!!!
Old Jul 16, 2004 | 10:20 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Ok heres how it goes...i got to take my cam out and im ready to put the other one in. Now how the **** do i get the lifters out from the stock cam? The one i bought is a kit and it comes with lifters and it says to install the lifters that came with the kit. Do i need some special tool or something? Please help!!!!!!!
Old Jul 17, 2004 | 12:12 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Head to Autozone, and rent the Hydraulic Lifter Removal Tool... otherwise, the big magnet (in their tool section) on the telescoping pole works really well at pulling the lifter up - if it gets stuck in the bore (which is highly likely) then just pull it out with pliers.
Old Jul 17, 2004 | 12:34 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I used my fingers/fingernails You can use a small pick as well. There are places on the top of the lifter to "grab" onto if you know what you're lookin at
Old Jul 17, 2004 | 01:04 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Long needle nose pliers for me. Works every time.
Old Jul 17, 2004 | 01:08 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Originally posted by Doward
Head to Autozone, and rent the Hydraulic Lifter Removal Tool... if it gets stuck in the bore (which is highly likely) then just pull it out with pliers.
1. Screw that POS- I went through two of them, both of which have broken- one jaw on the first one broke and the handle on the second broke, so I switched to the method I describe below.
2. Works great. Have someone with small fingers reach into the cam chamber through the holes in the top and push the lifters out until they stick (generally about 1/3 of the way out) and put a pair of pliers around the narrower portion if the lifter. Using the edge of the block or a block of wood as a pivot point, lift the lifter out (may take a lot of force depending on how many miles are on the lifters) and put the new ones in.
Old Jul 17, 2004 | 01:12 AM
V6sucker's Avatar
Engine: blown up
or a bent up metal clothes hanger is a great one too! I almost forgot that deal...
Old Aug 12, 2010 | 10:13 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Freaking Lifters!!!!!!
I had 4 that were stuck, came up to just before the narrow point was visible easily but then just stopped....after attempting several methods the one I found that worked, was gripping the inner and outer wall of the lifter firmly with large pliers and yanking fast, didn't work unless I yanked on it, otherwise it still just got stuck, posting this here because even though the thread is 7 years old I just found it cause mine are stuck so hopefully this method helps the guy that comes along in another 7 yrs :P
Also only do this if you're tossing them, otherwise you'll mar the machined surfaces and what not, but if you're pulling them, its probably to toss them.
Old Aug 13, 2010 | 08:41 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
N E C R O P O S T
Old Aug 13, 2010 | 10:22 PM
Engine: 3.8, 3.4
Way I see it, if I find an old post while looking for answers/solutions, then someone else will find it too, so if I have something useful/helpful to add I do...
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
