3.4 5 speed
Old Jul 29, 2004 | 12:18 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
3.4 5 speed
quick Q...is the 5speed transmission from the later model maro/birds with the 3.4L engine a T-5 as found in the thirdgens? Also, besides the obvious stuff needed for a auto/manual swap in any thirdgen car, what else would be needed for this swap, as i have access to power boosters, pedal assemblies, etc from the local they-pull-it...plus the guys cool w/ me....120 bux for the tranny.
Old Jul 29, 2004 | 12:40 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yes. You will need the flywheel/clutch from it, as well!
Old Jul 29, 2004 | 08:46 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
so the trannys from the 2.8/3.1 are the same as the 3.4 trannys?
Old Jul 29, 2004 | 10:24 AM
Doward's Avatar
No, they are not - they are all BW T5, and the 93-95 3.4's are WC T5, but with lower (numerically) gearing.
Old Jul 29, 2004 | 10:52 AM
drdave88's Avatar
Engine: 6.0L
i thought 88 and up was WCT5 trans? if not, what was the big change in 88? because a trans mount was about $100 for mine, and about $20 for 87 and back. i thought i read somewhere on here that WCT5 was 88 and up. ill look around. will a trans out of a 93-95 bolt right in to our cars or what all has to be done?
Old Jul 29, 2004 | 11:19 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
yes, 88+ is WC. 93-95 just got different gear ratios.
Old Jul 29, 2004 | 12:41 PM
drdave88's Avatar
Engine: 6.0L
so theyll bolt right in? what one has better gearing? ill be using mine for fun at the drag strip as well as driving daily.
Old Jul 29, 2004 | 01:22 PM
Doward's Avatar
The pre '93 ('88-'92) has a better first gear, but I believe the '93-'95 has a better overdrive...
Old Jul 29, 2004 | 11:41 PM
KED85's Avatar
I'll bet there is more than gearing to absorb better torque of a 3.4 5-speed in the 93-95 F Body.
Great score!
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
