Pacesetter Header Update Hopefully
Old Sep 2, 2004 | 11:47 PM
  #101
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Only one hole? So it's not 3 per manifold, like the 2.8's were? Where's the hole- in the y-pipe? Is it a big hole, like the EGR is?
You can tell how many 3.1 f-bodies I've seen in junkyards...
Old Sep 3, 2004 | 11:51 AM
  #102
BitchinRS's Avatar
Wow, one hole sounds strang.
Old Sep 3, 2004 | 12:19 PM
  #103
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
junkie, I am quite familer with threads as I worked in mfg plan for 3 years. I did not find any plumbing, or std threads that fit. I am assuming it is a large bore metric, which none of our local places carry anything that large.
Tomp, only one hole, approx 3/4" in diameter, or 19mm, very fine threaded.
Old Sep 3, 2004 | 01:46 PM
  #104
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Cool, just thought I'd throw that one out there. Also, it could be a custom thread.
Old Sep 4, 2004 | 09:46 AM
  #105
KED85's Avatar
Has anyone forwarded the smog pump clarifications to Mr. Fred Gerle of Pace Setter Exhausts?
Old Sep 5, 2004 | 01:01 PM
  #106
BitchinRS's Avatar
Karl,
Here's a copy of the e-mail I just sent to Fred.
Hello Fred,
I am very excited and greatfull for all of the work you have done to produce the headers for the 3rd generation v6 Camaro and Firebirds. I do have a question regarding the CARB E.O.# for them. I noticed that it is listed for the 85 - 89 2.8L Camaro. The production on the 3rd generation Camaro ended in '92. In '90 - '92 they used the 3.1L V6. It is the same block just with a longer stroke. Is this engine also covered?
The other point that has been brought up on www.thirdgen.org in the V6 section is the use of the smog pump. It appears some cars have the air directed into each exhuast port on the manifold and others in the catalytic converter, and we know of one member who has it directed into only one larger port. What effect will this have on the ability for these cars to be covered under the E.O. #?
Thank you for your time and effort!!!
-Will
Will most likely have to wait till after the holiday for a response from Fred.
Old Sep 5, 2004 | 10:48 PM
  #107
KED85's Avatar
THANKS SO MUCH FOR HELPING ALL OF US!
Fred Gerle is a great gent!
Have a wonderful holiday weekend!
Old Sep 7, 2004 | 12:33 PM
  #108
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Is there any word yet on when we will be able to get the Armor Coated Headers through Summit? Also, what are your opinions on the Armor Coat, is it pretty well the same as Jet Hot and the others? Is it worth the additional 100 or so dollars? What do you guys think?
Old Sep 7, 2004 | 02:58 PM
  #109
Dale's Avatar
Engine: 350 S-TPI
My guess for the coated ones is to do what I did.
Call summit, ask for KIP, extension 6511 I think, hes salesman 1314. Tell him you want to order the coated version. It will take a day or two, and he will get you price and time.
Old Sep 7, 2004 | 03:05 PM
  #110
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ah gotta love it when all the hard works pays off and use v6er's actually get some performance parts
Old Sep 10, 2004 | 12:32 PM
  #111
Do you have them yet Dale, its been 2 weeks hasn't it? Why is it taking them so long to ship them?
Where would I get copper collector gaskets? The only thing keeping me from ordering them is knowing how well they're going to fit. I'm dying here...
Old Sep 10, 2004 | 12:36 PM
  #112
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
they said upfront that it'd take about 3 weeks to get them after you place an order. after you order, i think that they still have to get them from pacesetter.
Old Sep 10, 2004 | 02:44 PM
  #113
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
yea thats where theyre getting them from. i was told the same thing when i ordered mine. i cant wait to bolt em up and go!!!
Old Sep 10, 2004 | 02:59 PM
  #114
Dale's Avatar
Engine: 350 S-TPI
I was told they would ship on the 24th
I suspect in hands about 28/29th.
I plan to install first weekend after having them (unless on piticular thing comes up, which I doubt).
I will do step-by-step install, notes, pictures, post them on my site. I also plan to use all hardwear given by them.
I will just have to have a um, adapter pipe made before I can drive it.
Old Sep 10, 2004 | 03:12 PM
  #115
drdave88's Avatar
Engine: 6.0L
....... and the race is on, lol
Old Sep 10, 2004 | 04:24 PM
  #116
adapter pipe...nice... I am most worried about ground clearance. Will the new exhaust dip down farther than the stock one? I assume there is, but is there a bung for the O2 sensor, and where is it?
edit: these are probably questions for Mr. Fred Gerle.
well...Fred got back to me within hours of me emailing him. He says that the O2 bung as about where it was, and that there shouldn't be any sort of ground clearance issues with the headers
Old Sep 10, 2004 | 09:53 PM
  #117
KED85's Avatar
When Mr. Gerle & I chatted about making the pipes, I mentioned ground clearance as a major priority of the design.
WHY
The exhaust system on 3rd Gens is REAL TIGHT DOWN THERE!
I also suggested boxing the pipes, not round pipes.
We'll find out soon!
I also mentioned clearance for us who want to install sub frame connectors (which I do so want to install, too).
Again, we'll see!
Old Sep 11, 2004 | 07:43 AM
  #118
Dale's Avatar
Engine: 350 S-TPI
Got notice overnight that mine have shipped.
Said to expect 3-4 working days. They may very well be getting installed on my b-day
:lala:
Old Sep 11, 2004 | 10:40 AM
  #119
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
:lala:
As long as that little hunny you've been photographing isn't around on your b-day
Old Sep 11, 2004 | 11:28 AM
  #120
Rebel 92 F-bird's Avatar
Car: 92 F-bird, 1965 Goat (GTO for those who don't know what a Goat is.)
Engine: 3.1 V6, 400 w/3 2 bbl's
Transmission: 700-R4, TH350
Summit now has a number for the coated headers. PSM-72C1206 sells for $293.99 ships on Oct. 10.
Old Sep 12, 2004 | 08:02 AM
  #121
drdave88's Avatar
Engine: 6.0L
did they notify you that they were being sent out or did you call them? hopefully that means mine are soon to follow, if not already
Old Sep 12, 2004 | 03:23 PM
  #122
Dale's Avatar
Engine: 350 S-TPI
I dunno what your talking about
Dave, they sent me email notice.
:edit: added tracking number
http://wwwapps.ups.com/WebTracking/p...x=26&track.y=9
Old Nov 7, 2004 | 10:48 AM
  #123
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
Ok guys quick but stupid ?
I have an 86 sport coupe 2.8 and the 5 speed behind it all pretty stock will theese headers listed fit it?
Old Nov 7, 2004 | 12:39 PM
  #124
KED85's Avatar
CERTAINLY!!!!
Keep supporting Pace Setter Exhaust!
REMEMBER TO ASK SANTA TO BUY YOU PACE SETTER EXHAUST SYSTEM FOR THE HOLIDAY FOR YOUR GIFT!!!
We all owe them a very big thanks!
Old Nov 7, 2004 | 01:35 PM
  #125
I can't remember if they ended up putting provisions on those headers for the AIR pipes on the driver's side.
Old Nov 7, 2004 | 03:42 PM
  #126
KED85's Avatar
For any questions
Contact Mr Fred Gerle at
fgerle@pacesetterexhaust.com
He's more than happy to clear up any confusion.
BE SURE TO THANK HIM FOR HIS HELP, TOO!!
Old Nov 7, 2004 | 10:55 PM
  #127
BitchinRS's Avatar
Karl,
I sent an e-mail over a month ago with no response. Witch tells me they have no plans to address this.
Old Nov 8, 2004 | 08:11 AM
  #128
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Screw the AIR pipes - did they fix the headers, to allow use of the PF52 oil filter?
Old Nov 8, 2004 | 08:20 AM
  #129
Doward's Avatar
Besides the filter, anyone notice no shipping till 12/6 on Summit's website?
Old Nov 8, 2004 | 10:05 AM
  #130
benoit454's Avatar
Car: 86 camaro
Thanks,
If it wasn't for just putting a ful exhaust on the car about 6 months ago, new cat, lead pipe, tailpipe and muffler, I'd buy me some headers and put em on but having headers and a single exhuast pipe kinda kills the purpose if I put headers on anything it gets duals, unless it was like a straight 6 or 4 cylinder lmao.
92projectcamaro
Jan 18, 2016 08:00 AM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
aharvel50
Sep 21, 2015 07:31 PM
hdis2002
Sep 8, 2015 02:52 PM
