Dyno proven 750 hp
Old 08-27-2004, 07:05 AM
614Streets's Avatar
Dyno proven 750 hp
Ryan Falconer 60 degree v6.
Old 08-27-2004, 10:16 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
looks like dual turbos, dual plane custom intake. FWD heads??
Very long runners for torque, injectors installed up high. Good for atomizing, but bad on throttle response.
Any exact specs on it?
Old 08-27-2004, 10:36 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
something tells me you might need a cowl hood with that motor heheh...
Old 08-27-2004, 11:13 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
lol doubt many 350's out there could keep up with that thing
Old 08-27-2004, 11:18 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I think we're actually looking at dual banks of injectors. It looks to have one high and one low on each runner. 12 injectors total.
Old 08-27-2004, 11:19 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
damn that thing is a monster
Old 08-27-2004, 12:04 PM
Dale's Avatar
Engine: 350 S-TPI
Good eye, your correct.
Old 08-27-2004, 12:37 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Forget the cowl hood, that lil toy would be very very nice on say a dune buggy or sand car.
Old 08-27-2004, 12:42 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Man.. that plenum looks almost exactly like what I have in my head.... the intake's a little off due to it being far beyond my capabilities, though, but the runner length is about right. A little tighter on the bends using mandrel bent pipe for the runners... and only one set of injectors will keep me happy.
Old 08-27-2004, 01:06 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I must have missed the dyno proven part
Old 08-28-2004, 01:41 AM
614Streets's Avatar
I understand where you coming from. Wish I could prove it to ya. I snaked this post from 60degreev6.com.
However this is a product of Ryan Falconer
Check out Ryan falconers website if you even think about flinching about what this little 2.5 or 2.8 is in its crazy Twin turbo form.
Im not 100% sure thoose are GM heads.
I thought they could be the potter v6 heads?
Old 08-28-2004, 03:35 AM
JesasaurusRex's Avatar
Wonder how much that cost to build
Old 08-28-2004, 01:42 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i want to see that in a car, and see what it can do
Old 08-28-2004, 03:35 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
....wow......Good find. Imagine this, you pull up to the local strip, make a 10 second pass (with a very unique sounding exaust note), a pro stock guy walks up and asks what you're running, "Oh it's just a 2.8L V6...". I want one....
Old 08-28-2004, 03:48 PM
614Streets's Avatar
That would go 9's easy. Also its destroked or sleeved down to 2.5 liters from what I was told.
Old 08-28-2004, 03:51 PM
br()bert's Avatar
Car: 85 firebird
If they can do that with a 6 i wanna see what they could do with a 8
Old 08-28-2004, 05:48 PM
FbodTrek's Avatar
I've seen 8's that would blow your mind Brobert, but they don't look like that. That motor by itslf is a work of art even on an engine stand (much like an F1 motor). I've seen 1200 motors up close and personal, they look pretty plain jane (except for the direct port setups). I imagine they destroked it to rev higher and lower the compression (the pistons are probably of a very unique design). That motor s probably running a VERY high amount of boost, the turbos are very large for the displacement (Doward, what do those look like to you ). Thing probably revs to 10k or more.
Old 08-28-2004, 08:45 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Definetely Garret turbos... looks like a set of T4's, possibly hybrid T3/T4s. Hard to tell with the compressor side facing backwards
Old 08-28-2004, 08:46 PM
Doward's Avatar
Btw, that won't fit in an Fbody
Old 08-28-2004, 09:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
haha sawzall and a bfh and anything will fit
Old 08-28-2004, 11:46 PM
devianb's Avatar
Personally that kind of motor looks scary with all those custom parts. Lol if something breaks not like you can just order it from anywhere, most likely have to have it custom made again. Looks very high maintance too me, but still impressive looking.
Old 08-28-2004, 11:50 PM
ljnowell's Avatar
I think its bitchin'. I still have my old 2.8 in the garage, maybe they sell the components. I wonder if anyone here has ever done the 350 > 2.8 swap?
Old 08-29-2004, 12:20 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
I would definately say it was built for a boat- Lightweight and powerful.
He is specializing in V12's right now mainly for cigarette boats that put out aprox 1000hp+ and a whole lot-o-torque.
What sucks is I have e-mailed them three times and now reply. I'll have to find time to call them during business hours. I want to see what he has to offer (if any) for 60*V6's and if I can get ahold of one of his early FI intakes.
Old 08-29-2004, 12:24 AM
85f-bird's Avatar
Engine: 2.8L, LS1
If you're in the business of making custom parts for high performance (and that's what he does, high performance) automotibles, and especially the parts he's making for aircraft then reliability is more likely then not at the forefront. (do you want your engine to destroy itself at 10,000 feet? I don't)
Also, it doesn't look particularlly high maitnence, while running it will definately call for the need to replace parts and inspect parts on a somewhat regular basis, the confusing parts of things such as our cluttered engine bays, numerous amounts of switches, and the cars being made to meet federal standards, not highend automotive/aircraft standards, that i'm thinking it would probably do very well, and depending on instalation, would probably be a very easy engine to work on.....however, keep in mind the the tolerances of an engine such as that would be so critical, that attempting to get something working proerly w/o propper knowledge, might give you an iron block and aluminum head custom made boat anchor.
Old 10-30-2010, 05:48 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Dyno proven 750 hp
Yeah I'm necroposting, but does anyone have the link to this thing or a picture, since it no longer works....would love to see that engine......
Old 10-30-2010, 03:46 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Old 10-30-2010, 03:49 PM
Engine: 3.8, 3.4
I'm not sure thats the same engine, they mentioned dual turbos, and while the one you just posted is deff a beast, I don't think an N/A 3.4 could possibly hit 750 hp...400 probably...but not 750..
Old 10-30-2010, 03:56 PM
grimmcs's Avatar
Car: 91 Camaro
ah geez...Honestly I stopped reading when I saw the age and Falconer.
That one defiantly is a Ryan Falconer engine...but good luck finding the original pics from this thread. Probably buried deep within the interweb.
Old 10-30-2010, 04:23 PM
Engine: 3.8, 3.4
And I just noticed thats a fiero that the one you linked is in
Old 10-30-2010, 09:12 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Ooo, me want to see more! Anyone have pics? Google doesn't help as far as I can tell.
Old 10-30-2010, 10:57 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
That is...PURE ART.
Old 10-30-2010, 11:10 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
man, i need those air cleaners.. lol
RedLeader289
05-28-2019 01:47 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
Briandrex
10-05-2015 06:20 AM
Quick Reply: Dyno proven 750 hp
