2k idel
Old Sep 6, 2004 | 10:47 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
2k idel
my car idles at 2k-2500 after i changed the tps, i unpluged the IAC and no change
Old Sep 6, 2004 | 11:57 AM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
Did you use a scan tool when installing the TPS? If I remember right you adjust the TPS sensor so at idle the voltage will read .54 volts + or - .005 volts on the scan tool. Its also possible you have a bad TPS new from the box. It sounds related since I assume its idled ok before you changed it.
Old Sep 6, 2004 | 12:25 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
90-92 SD TPS aren't adjustable, nor can TPS signal level be responsible for a 2k rpm idle. Chances are the little tab on the TPS that meshes with the throttle linkage is on the wrong side of the throttle and holding it open. Simple fix to remove it and reinstall with the tab on the correct side.
Old Sep 6, 2004 | 08:20 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i'll try it
Old Sep 13, 2004 | 08:16 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
good news guys i took out my IAC cleaned it up and my car no idles at 2500 also tried re-doing the TPS and no change
dvondman
May 3, 2003 06:52 AM
ypipe
May 2, 2003 10:02 PM
1bad350
May 2, 2002 11:20 PM
86BIRD-MY FIRST CAR
Mar 10, 2002 03:23 PM
85 lg4
May 26, 2001 09:58 PM
