View Poll Results: Was there a big difference in throttle respnce between a 2.8 VS 3.4??
big difference
57.14%
less difference
28.57%
about the same
14.29%
Voters: 7. You may not vote on this poll
for all the 2.8-3.4 swapers more power? less power?
Old Sep 16, 2004 | 05:04 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
This is a post for all the 2.8-3.4 swaps....
how did the swap go?
did you have to alter anthing for it to work?
did you change the chip?
was there more power and was there a big difference in throtle responce?
sccamaro88
Old Sep 16, 2004 | 06:24 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
my 2.8 was DOA when I got the car. Ididmy swapa alittle different than most inthat I kept the 3.4 serp beltrouting. As always, be aware of the pipe plug in the rear pass head, where the 2.8 fan switch is. And becareful ofbreaking the factory plastic hardlines (which are available in the "HELP"section now).
May as well inspect/changemotor mounts while the engien is out.
I also have some pics of the swaps on the cardomain site.
Old Sep 16, 2004 | 07:22 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
:LOL Heck yeah there's more power! You'll have more acceleration, more torque, more tire spinning. It's a night and day difference! I went from a G-tech best of 18.1 to a G-tech best of 16.3 by just swapping the motor. The G-tech is off, I know, so I took the 3.4 to the track as well. I ran a 10.75 1/8th. That's a high 16 mathwise (don't trust conversions though). After a cam and hedders, I went a 10.02 (ran after the hedders, ran a 10.65, did before cam swap). There are some decent times to be had with a 3.4, really good swap.
Old Sep 16, 2004 | 08:52 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 to 3.4 here. I did a slightly different swap as well, but not major. Kept 3.4 oil pan, 3.4 oil housing, started off using 2.8 fuel rail and lower intake. Quickly switched back to 3.1.
Swap went fairly easy, tad bitch alighning back up to the trans and stabing distrib in (me and distribs dont get along).
Only alter made to make it work was move the knock sensor.
Still running stock chip
Noticable power, but not night and day like others say.
Old Sep 17, 2004 | 12:30 AM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
When I did my 3.4 swap, with the great details from KED85, I simply came up with the conclusion that this is equivalent to swapping a 305 for a 350. The 2.8 though, was/is a better motor than a 305. The best 305 was the limited availability fi/215 horse motor later replaced with a 190 horse carbbed motor in the 80's.
That's my take.
Rick
Old Sep 19, 2004 | 08:23 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
when i pulled my 2.8, i had leaking injectors and it was just tired. my 3.4 only had 57,000 miles on it. i resealed/gasketed everything but the internals on the block. it also got a new oil pump. i noticed a huge difference before and after. i also did some other mods during the swap though. best thing you can do, aside from turbo
Old Sep 20, 2004 | 02:04 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
haven't done it yet, but don't expect to be runnings 13's in it. it will be better then you current motor and you will thank yourself for doing it
Old Sep 21, 2004 | 02:28 PM
SCcamaro88's Avatar
lol im hoping theres a difference, my 2.8 ran good though. When i blew the engine, i was depressed for days lol. my friend has a 2.8 but it didnt run like mine....which was odd i thought. well im geting the 2.8 swap to a 3.4 done and its only been 2 days and it feels like its been 2 years hope it turns out ok
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
