87 and 89 similarities?
Old Sep 22, 2004 | 05:41 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I found an 89 firebird (V6 i think) with gauges dash. Will this be a direct swap (I have idiot lights on my 87). What will I need to grab to do this? Is all the wiring aready there (specifically wiring related to temp gauges). Is there also any difference in the steering rack between the two years (from one ball joint all the way across to the other)? What about struts? I found a wreck that looks like it had the front suspension rebuilt not to long ago and need to know if they're interchangeable. Any help is appreciated.
Old Sep 22, 2004 | 05:55 PM
RedTtop5spd's Avatar
Car: 99 SS
The guages can be swapped with just a couple extra things pretty easily. I know someone else out there can handle that question better so I'll let them field that. The front suspension is completely interchangeable.
Old Sep 23, 2004 | 02:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
every bit of it will swap, with little to no problems
Old Sep 23, 2004 | 05:49 PM
sixbanger's Avatar
so iis the tach/temp gauge a direct replacement?
Old Sep 23, 2004 | 08:21 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yep all the wiring should already be in the car, just needs to be hooked up
you live in north delta don't you?
i'm just off 108th and 144th in surrey
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
paul_huryk
Oct 1, 2015 04:27 PM
MadOTC
Sep 28, 2015 09:30 PM
abray1
Sep 14, 2015 08:18 AM
