Total Help
Old Nov 14, 2004 | 02:45 PM
promodvette's Avatar
Car: 91 Camaro
Engine: 280ish
Transmission: torqflite 3 speed
Total Help
Ok...Im out to build the fastest v6 stock suspension car out there... engine will be about 280inches splayed valve etc etc..all the good stuff where do i get headers for this thing?? Do i gotta build em or does somebody make some? I saw some that were 1 1/2 but i think that might be too small for this application...where do i get valve covers for those heads? Or is that another thing i gotta make? For the chassis ive got
BMR extreme duty torque arm
BMR rear anti roll bar
BMR extreme control arms
Jegs 12 point cage
Competiton Engineering Subframe connectors
AJE k member
What else should i get? Whats the fastest v6 camaro out there right now in the 1/8 and or 1/4?
Old Nov 14, 2004 | 04:23 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ok with all that suspension stuff listed there, its not gonna be a 280 horse stock suspension car
but, pacesetter makes headers for our cars and the valve covers should probably be feiro valve covers or edelbrock
Old Nov 14, 2004 | 04:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If the primaries on the pacesetter headers are too small for your application, you'll have to build your own. Pacesetter is our only ray of sunshine- they're the only company that makes headers for our 2.8/3.1/3.4 in an f-body.
I believe Hooker (or Heddman) makes a set of 2.8 headers for an S10 truck, but the headers won't fit our engine bay, so you'll have to do alot of bending- and they might have the same size primaries.
Old Nov 14, 2004 | 05:32 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
This guy is talking about a 90*V6.
Old Nov 14, 2004 | 06:20 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yes, he's gotta be, Dean... the 3.4 is only 207ci.
Maybe a 3.8? TTA setup? Who knows....
Old Nov 14, 2004 | 08:44 PM
Car: 91 Camaro
Engine: 280ish
im buying the block and heads from pace performace and all the other stuff from my usual suppliers...just the intake is $2400....i figure it will be in the 650-700 hp range if not more i really havent messed with v6's before. We have a 281 inch v8 chevy motor that makes close to 800hp and thats not a splayed valve head...im gonna have the intake already drilled for juice just put plug in it untill im ready. I can also run this motor in a pro stock cavalier in nhra comp elim...similar motor has went some 8.40's in the 1/4...i just want to bust some moostang *** around here...they are runnin in the 6.50 range in 1/8 i think i can run in the 6.00 range on motor if the car works right
Old Nov 14, 2004 | 08:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if he is talking about a 60*, on the valve cover subject, the fierro covers are a no go because he says splayed valves which would have to be the aluminum heads. i don't know about any valve covers for them. the old hooker headers for our v6 have smaller primaries than the new pacesetters do.
i'm also a little confused on the "fastest v6 stock suspension car out there..." here's all of my suspension mods...
edit: just read his 2nd post, this has got to be a 90* motor if he's buying the block and intake and all like he says. also, for tranny (listed under username) it says torqueflite 3 speed. that doesn't sound like anything i know of behind a 60* motor.
Old Nov 14, 2004 | 09:31 PM
Car: 91 Camaro
Engine: 280ish
yes it is the 90 degree motor....it is considered stock suspension because its bolt on in stock loaction just aftermarket parts. Its not going to be 4 link or ladder bar or swing arm type deal..."stock"
Old Nov 15, 2004 | 02:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, haha, I didn't even notice all that, I figured it was about one of our v6's.
Old Nov 15, 2004 | 03:54 PM
Car: 91 Camaro
Engine: 280ish
it is...just in a bigger kinda way...after i get it done it will give yall (i can say us now) v6 guys somethin to brag about...a v6 camaro that will outrun a v8 stang or whatever else they want to try me with...and if the camaro doesnt do the trick i gotta 4.00@181 corvette sittin right beside it! but thats a whole different ballgame...
Old Nov 15, 2004 | 04:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, not in my case; b/c I'll have the 60 degree V6. But best of luck to ya!
Old Nov 15, 2004 | 07:49 PM
Car: 91 Camaro
you building a 4.3 or what? sounds good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Nervous2
Oct 8, 2015 10:53 PM
jaridjohn
Oct 5, 2015 07:01 AM
david068513
Sep 18, 2015 10:36 AM
