3.8 Bellhousing Question?
Old Nov 16, 2004 | 11:19 AM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
Does the 3.8 90*V6 have the same bellhousing pattern as a 3.4, 3.1, 2.8 60*V6?
Or is it the SBC Bellhousing pattern?
Old Nov 16, 2004 | 04:21 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
they gonna have the B-O-P bolt pattern.
Old Nov 16, 2004 | 04:58 PM
so in other words a 5 speed that is on a 3.4 will not bolt up to a 3.8?
Old Nov 16, 2004 | 05:49 PM
Engine: 5.7 / 7.4
if you switch bellhousings it should, but I'll let those who've worked on 3rd gen sticks answer that one.
Old Nov 16, 2004 | 08:50 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
the 3.8 is a 90 degree engine, the 3.4 is a 60 degree, so the bellhousings are definitely different, probably the same as the 4.3 or the v8s. it is likely that the 3.8 has the same input shaft as the other 90 deg engines, you would probably have to get an adapter clutch and a diff flywheel as well.
speculation however. all i can guarantee is that the bellhousings are different.
Old Nov 16, 2004 | 09:37 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you use a 3.8 from a front wheel drive, It uses the metric bolt pattern of the 2.8 and 3.1. If you use a rear wheel drive 3.8 block from the 80's, It will use the b-o-p pattern. McLeod sells a bellhousing that bolts to both che*y and B-O-P engines and has the tilted bolt pattern for the t-5 in the 3rd gen. You must buy a Buick even fire v-6 flywheel but it is drilled for the same bolt pattern as v-8 clutches. Also check the back of the crank. Some 3.8's were not machined for a pilot bearing.
Old Nov 17, 2004 | 04:51 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Nate, doesn't the 3800 you put into your car have the metric bolt pattern? I had a 3800 out of a Firebird and I swear it had the metric bolt pattern. Sorry, if I'm wrong. I just want to clarify because of a 'future' project.
Old Nov 17, 2004 | 04:59 AM
the 3.8 is a rwd out of a late model Camaro
the 5 speed is out of a 95 camaro 3.4
Old Nov 17, 2004 | 05:34 AM
Engine: 5.7 / 7.4
WHen I hear 3.8 I think of teh 80's GN/TT/A engine, not the 3800 Series II. Just my mind set.
The 2.8~3.4 rwd blocks have teh same tranny bolt pattern as the Series II sos the tranny combo is 2.8~ 3800 II.
There shouldn't be any issues w/that combo.
Old Nov 17, 2004 | 05:57 PM
thank you very much, yeah i should of mentioned it earlier.
AussiePr0nCar
Mar 6, 2020 04:04 PM
neilb
Oct 4, 2018 12:36 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
