exhaust manifolds get RED HOT!
Old Nov 23, 2004 | 06:17 PM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
Transmission: TH 700R
just noticed on the left side of engine that the manifold gets super hot i mean it glows! at night!! and burning my spark plug wires and melting them! plus the car doesnt run good at all its real sluggish at take off and hesitakes alot durning aceleration... like theres a blockage also i have had the manifold gaskets replaced and i think before this it ran like that but no where near as bad as now... any idea what i should do i wanna fix it my self
Old Nov 23, 2004 | 06:22 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Runnin' really lean! Not cool!
Old Nov 24, 2004 | 12:21 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
get it fixed, before it costs you alot of cash
Old Nov 24, 2004 | 02:35 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
would say either lean or retarded
and I don't mean stupid type of retarded
if you can see what the voltage reading on your o2 is
while not perfect if your seeing really low volts and you know the 02 is running right your running lean
also check the timing
Old Nov 24, 2004 | 06:47 AM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Your cat could also be clogged Make sure its not, I heard this problem and it was just a clogged cat. Hope it helps
Old Nov 24, 2004 | 07:31 AM
danwaite's Avatar
Car: 91 Pontiac Firebird
Engine: 305 soon 350
My friends 350 used to do that, but that would be after racing, his motor was built up and that would be after racing up and down this corn field side road. You could almost light a cig off of it. But his always ran well. Like said above I would check out to see how lean it's running and check that timing. Before it's to late and something gets seriously messed up, like a head
Good Luck
Old Nov 24, 2004 | 07:35 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
my money is on a plugged cat convertor. ive seen it on a couple different vehicles.
Old Nov 24, 2004 | 08:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a plugged cat will glow too.
Old Nov 24, 2004 | 08:19 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Check your timing and cat! When we first did the 3.4 swap had some running issues with timing. We got the ex. manifolds so red. No damage though! It was the timing for us though!
Mom's 2.8 had a bad clogged cat. Car would barely run. Flat would not accelerate. Cat glowed, but manifolds did not.
Old Nov 24, 2004 | 09:04 AM
Jaswir's Avatar
Car: 88 Camaro RS
Engine: 2.8L v6
i pulled the coverter off and looked at it and wasnt cloged at all... i guess i will check the timing out and see if thats the problem... my 02 should be working right because i recently replaced it
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
