driveshaft measure in V6 700 R4?
Old Dec 14, 2004 | 05:19 PM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
Hey guys, I am working on my Berlinetta 85 V6 drivetrain and I just bought a new 700 R4 for replacing the old 350 this car has right now. Now the thing is, what driveshaft should I put now? a specialized guy told me that I need to get a new one because the current will not fit with the 700 R4 tranny, so I would like to know how long is your V6 driveshaft so I have a clue which one to buy. Thanks!!!
Old Dec 14, 2004 | 09:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're saying your '85 Berlinetta has an old TH350 as a trans? That wouldn't bolt up to the 2.8! You sure it's not a TH-200C? But even That doesn't make sense... you should've had a 700r4 in there already.
Any 2.8/700r4 junkyard driveshaft will work... actually you can take a V8 f-body's driveshaft, too.
Old Dec 14, 2004 | 10:18 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ya man
Old Dec 15, 2004 | 06:32 AM
watafo's Avatar
Engine: V6 2.8L
Well, that is what the mechanic told me, what I can tell you is that the car has 3 speeds only, plus reverse. I am gonna take it to another mechanic to see if he thinks something different.
Lets see what happens... Thanks for all TomP, and you too Berlinetta85.
Old Dec 15, 2004 | 07:30 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Re: driveshaft measure in V6 700 R4?
Okay, from what I'm reading you have an early berlinetta (82-84) that had the 85 drivetrain swapped in? That makes sense since 82 and 83 cars had the TH-200C. Mechanic is probably just assuming that since it's a 3 speed, you have a TH-350.
ANYWAY, hit the junkyards,. You need a v6/700R4 drive shaft, AND crossmember, AND torque arm. After you have all of that, you should be good to go. Replace any rubber parts with polyurethane components from energy suspension.
Might want to get the shifter and all related cables leading to the tranny as well.
Old Dec 15, 2004 | 09:41 AM
watafo's Avatar
Engine: V6 2.8L
Thanks for all, I am working on all that stuff and I would like to put better components in this new tranny, like the ones you said.
Old Dec 15, 2004 | 11:18 AM
watafo's Avatar
Engine: V6 2.8L
I forgot to say that my car is an 85 MPI V6.
Old Dec 15, 2004 | 11:52 AM
MDv6man's Avatar
Car: 1983, 1986
Right but what TomP and I are trying to figure out is how you have a 3-speed trand in there. All automatic trans equipped cars after 83 (84 and up) got a 700R4. 82 and 83 had a 3-speed. They were all a TH-200C. A TH350 would not bolt up to a 2.8 v6 due to the different bolt pattern.
I'm suggesting that maybe your Berlinetta is an 82 or 83 with the MPFI added by a previous owner.
Old Dec 15, 2004 | 12:18 PM
watafo's Avatar
Engine: V6 2.8L
The car label on the door says it was built on 11/84, the car title says it is an 85, it could be a TH200, I do not know if the TH200 has Torque Converter Clutch but this one has it.
Old Dec 15, 2004 | 12:21 PM
MDv6man's Avatar
Car: 1983, 1986
Alright its an 85. The TH200C that came in the 82 and 83 Camaros did have the TCC lockup.
Why anyone would remove the 700 R4 and put in a 200C is beyond me.
Old Dec 15, 2004 | 01:33 PM
watafo's Avatar
Engine: V6 2.8L
Well, what I think is that the former owner damaged the 700 R4 and putted a cheaper tranny to keep the car alive....does it make sense for you?
Old Dec 15, 2004 | 01:48 PM
MDv6man's Avatar
Car: 1983, 1986
Sure does except he would of had to change out a bunch of other stuff as well (basically all the stuff I said you need to go back to the 700R4).
Anythings possible
Old Dec 15, 2004 | 02:18 PM
ljnowell's Avatar
Re: Re: driveshaft measure in V6 700 R4?
Not all necessarily from a V6 car.
Old Dec 15, 2004 | 02:19 PM
watafo's Avatar
Engine: V6 2.8L
You see....now I want it to get the original tranny so if you have more ideas to improve the tranny performance, let me know
Thanks for all!!!
Old Dec 17, 2004 | 04:29 PM
watafo's Avatar
Engine: V6 2.8L
TomP or other guys, do you know how many pounds an 700 R4 weight?
Old Dec 17, 2004 | 04:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
about 150lbs.
The 4L60-E I got to replace my dead one w/packing jsut made it by the UPS scales of the 150lb weight limit.
Old Dec 17, 2004 | 04:58 PM
watafo's Avatar
Engine: V6 2.8L
Thanks Project 85!! I was so freaking confused because someone told me around 80 lbs and other told me 275 lbs!!!
If you experienced it already, there is no doubt now.
Old Dec 17, 2004 | 05:25 PM
watafo's Avatar
Engine: V6 2.8L
I forgot to mention........is it including the TCC?
Old Dec 18, 2004 | 05:52 PM
watafo's Avatar
Engine: V6 2.8L
Hey TomP, guys, look what I found on the tranny.......I am not sure if you could see it , but it says MD8.....
Old Dec 18, 2004 | 06:00 PM
Engine: 5.7 / 7.4
the weigth was for the tranny only, no torque convertor or lines. mostly dry weight
Old Dec 21, 2004 | 10:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Good picture!!! And going by the pic, that's really freakin' weird then; the MD8 is the 700r4 trans. Huh. But you just have three speeds???
I wonder... could it be, and this is stretching it... but that you've got a 3-speed shifter and shift plate?? And you've really had a 4th gear all these years, but the shifter didn't let you get to it??
What's the tranny pan look like? Is it square?
Oh and when I dropped my trans out, I was able to pick it up; it's not 275 pounds. Unless I was stronger than I thought!
Old Dec 22, 2004 | 01:28 PM
watafo's Avatar
Engine: V6 2.8L
TomP, I just realized that the car has 4 speeds. The mechanic was wrong and I took care of this by myself.
So you picked it up?...the guy who sold that tranny to me said that it is about 130 lbs...max 150..lets see.
Thanks for your help!!!
Old Dec 22, 2004 | 04:27 PM
Engine: 5.7 / 7.4
probalby 145. I got mine in a cardboard box w/lots of tape, foam & styro-peanuts.
Xanath
Jul 2, 2008 06:15 PM
dpmalibu
Feb 17, 2008 04:47 PM
chickenhawk
Aug 4, 2006 01:38 PM
TRAXION
Apr 26, 2003 03:35 PM
Sinful One RS
Jul 7, 2001 09:58 PM
