How much more power?
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I'm planning to do a few things to my car since my job cut my hours and school has not started yet.How much more horsepower APX will this add:
Removal of AC Compressor
Adding Underdrive Crank and Alternator Pulleys
Adding a Magnaflow High Flow Cat
Throttle Body Coolant Bypass
Im guessing around 15 HP all togather from the underdriving,extra exhaust flow and weight removal.
Car: 91 Firebird
Engine: 3.1 V6
Originally posted by kretos
don't bother with the alternator under drive pulley, you will run into charging issues
Car: 3
Engine: inboard
Transmission: underfloor
Hate to burst your bubble, but I don't see fifteen horsepower at the rear wheels there.
3-5 at the most.
Removing the AC compressor didn't add any power, it took away 15-20lbs, but when the clutch isn't engaged it doesn't use any power.
The Magnaflow cat may flow more than the stocker, but the real restriction is in the manifolds and "Y" pipe that preceede it.
I'm not tying to be hatin' on ya, and I know you want to make some more power, but don't get overly optimistic about it.
3-5 at the most.
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
even though you don't have anything major putting starin on the alternator, you will still run into problems. the gain vs the risk is not worth the price for the pulley
Car: 91 Firebird
Engine: 3.1 V6
3-5 at the most.
3-5 at the most.
Car: 1985 Z28
Engine: 305 LG4
It can't possibly take 4-6 hp to turn it. Take the belt off and turn it by hand; it spins effortlessly.
Also, I just put a high flow cat on my car and it made no difference in power. It does sound better though
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Originally posted by V8 Slayer
Hmm 3-5 HP most is pretty weak considering that like over $100 worth of mods.
Car: 3
Engine: inboard
I second that F-Bod.
V8 Slayer, we're not here to try and discourage you from modding your car, but a lot of us have "been there, done that" and learned form our own mistakes as to what works and what doesn't.
Keep in mind everything you hear on TV and in the Mc Donald's parking lot ain't always true, and we'll help you sort out the monkey spank from the fact
If you want noticeable power out of one of these, look at some of AIM91's mods- he put a LOT of effort into porting the heads, combined with boosting the compression and a good set of headers. Then he combined it with a converter matched to the engine's powerband and 3.73 gears.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Originally posted by FbodTrek
Outside of port work and custom type stuff, there isn't much you can do to these cars to make a decent amount of power for under 100 bux.
(On the other hand, the setup basically put the nails in my old 2.8's coffin... that's gonna cost more than $100 to rectify.)
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Maybe it takes power becasue its an old stly compressor and they did something different then the newer free spinning ones
Originally posted by TechSmurf
Does fabricating your own turbo system count as custom type stuff? I'm hovering around a $110 investment currently if I count some of the flex exhaust I'm using to finally pipe the exhaust OUT of the engine bay...
Engine: LS1, Scrap
Status report is pretty simple.. I'd rather drop in a 3.4 than go about giving the small journal 2.8 new bearings and valve seals
.... absolutely no faith in that motor.
.... absolutely no faith in that motor. Supreme Member
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
weight reduction & suspension. make the most of what power you have, then decide on what other combo of mods in the order that you cain afford shoudl come next.
