TDC Question
Old Apr 24, 2005 | 03:21 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
TDC Question
So if number one cylinder is at top dead center which one is at the bottom on my 3.1?? Or tell me how i can get to the number one cylinder and pull the spark plug because it seems like the egr system and alt bracket is totally in the way.
Old Apr 24, 2005 | 03:25 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
you can get to all the plugs with a wratechet extension and a flexhead without removing anything.
Old Apr 24, 2005 | 03:29 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
ok thanks but i still need to know which cylinder is at bdc when #1 is at tdc
Old Apr 24, 2005 | 04:56 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
comon guys this is easy
Old Apr 24, 2005 | 05:12 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Absolutly does! Thanks alot!
RBob's Avatar
Car: check
Engine: check
Transmission: check
Trick question, none are at BDC while #1 is at TDC. #4 will be at TDC exhaust while #1 is a TDC compression. Does that help?
RBob.
Old Apr 24, 2005 | 05:46 PM
KED85's Avatar
Passenger side front cyinder is number one
Remove the plug, plug up hole with your finger, crank over engine, await the finger to be popped off by compression and then go check the timing mark on balancer. You should be "right there" after several attemps. Get your timing mark to "zero" as that's more likely TDC.
PS Remote starter will be your best friend for doing this! Girlfriends/Wifes haven't the patience! or care.
Old Apr 24, 2005 | 06:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Especially when "Hon it'll just take 5 minutes" turns into an hour! And forget about asking for help bleeding the brakes... yikes... after the first time, you'll never get help again!
Old Apr 24, 2005 | 08:29 PM
KED85's Avatar
I must admit my Wife isn't so bad at brake bleeding. Cranking over help is "really borderline". Get the remote starter for best help at your own time frames!
Old Apr 25, 2005 | 12:30 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
ya but theres like WAY too much stuff in the way to even get close to getting my finger in there, thats why i was asking which cylinder matches up with number one, so i can use another cylinder to get tdc.
Old Apr 25, 2005 | 04:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You should be able to at least snake a piece of vacuum tube into the plug hole; when the tube stops rising, you're at TDC. (Man, I'm glad I have a 2.8 and can get to everything!) Of course you still have to make sure you get the compression stroke.
You might be able to stuff a rag (not paper towel) into the plug hole; when it blows out, you know you've got the compression stroke; then you could shove the vacuum hose in and find TDC.
Old Apr 25, 2005 | 11:00 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
ya i could do that....... but would there be any problem with just getting #4 to exaust tdc and assume thats #1 tdc compression? I cant think of anything can u guys
Old Apr 25, 2005 | 11:10 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
At at the point in life that I can't even get the wife to wash the car in her bathing suit anymore while I sit and man the spray nossle. Life just sucks when they turn 40
Old Apr 26, 2005 | 12:07 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
ok, so why are you having so much trouble w/ TDC of number one? The most common way is to put a finger over the sparkplug hole, i've never thought things were that cramped, atleast not in my 2.8, in the 3.1 maybe the EGR components are way in the way, however, (i'm not a small guy) i can still get to any cylinder at any time, and yes, a socket/swivle/extension setup tends to work best.
see what you can find to put on the plug hole to find compression stroke, using a rag can also work, and i've heard of people using a screwdriver (what my teacher once taught us). if you use the latter, rotate it by hand, i really wouldn't want a starter spinning a screwdriver up and down in my cylinder at 300 RPM. A piece of Stirdy rope works, along w/ vacuum tubing, etc...anything that will hold it's shape.
Giving our compression strokes being 120 degrees out, it'll be a little more to determine TDC/BDC relationship that it would be on a 4 or 8 cylinder engine.
Old Apr 26, 2005 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Depends upon the reason you need #1 at TDC.
RBob.
Old Apr 26, 2005 | 04:32 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
because when i pulled my dist i screwed up i think and now my timings all off. i just want to start brand new so when i put my dist back in it is right on with the timing.
Old Apr 26, 2005 | 06:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Oh, OK, in this case set #4 (middle drivers side bank) to TDC (compression) and set the distributor in with the rotor pointing at #4 plug wire terminal.
Firing order being 1-2-3-4-5-6. Just count around the cap, clockwise, looking down from the top.
Get it running, disconnect the EST connector, and time it. Can put the timing light pickup on either #1 or #4. No difference (I use #4 for the same reason you are going to). Just set to 10° BTDC. Shut off engine, re-connect EST, remove timing light, then can drive car.
RBob.
Old Apr 26, 2005 | 07:12 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
fantastic thats great to hear thanks alot!!
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
