Need horn to work!
Old May 4, 2005 | 10:36 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Need horn to work!
Is there a fuse for the horn on a 91 bird? I looked and cant find a horn fuse
Old May 5, 2005 | 08:50 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I got the same problem in my car, no horn, no blown fuses...least not that I can find.
Old May 5, 2005 | 11:48 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
horn probably died. check it for power when you push it. if theres power to em, get a new horn.
Old May 5, 2005 | 11:53 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
check for power? how...nothing happens when I push on the steering wheel.
Old May 5, 2005 | 01:30 PM
drdave88's Avatar
Engine: 6.0L
use a test light and disconnect the connector. have a friend press the horn and one side will light up, that means you have power and the horn is bad. if you dont have power on either side, then you dont have power getting to the horn and have a problem in the wiring.
Old May 5, 2005 | 04:16 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
In my camaro they use plastic buttons over time they get brittle and brake like mine did. They just pop out how ever where the connecto goes into the steering shaft i broke the plastic clip off so i have no horn anymore.
Old May 5, 2005 | 07:42 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
my horn filled with water and stopped working. get a few from a wrecker for 5$
go in from the wheel well, move the plastic liner
Old May 6, 2005 | 07:50 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
my horn broke, the shop told me it would cost 1100 to fix it caz of the airbag. so i had to get a button that bolted to the dash to use to make the horn work. Looks like ****
Old May 6, 2005 | 08:50 PM
FAST RS's Avatar
Disconnect the battary. Then below the dash there is a yellow wire disconnect it that will disconnect your air bag so it will not go off. Then thake a allen wrench and remove the allen bolts from behind the steering wheel 4 bolts. The air bag will come off and you will see in the corners the contacts for the horn you can get new ones from GM about 15 dollars put them in and you are good to go.
Old May 7, 2005 | 02:29 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
YES! Just the thread I needed. Everywhere around here wont pass me unless I have a horn but I have lots of problems that are my fault lol, but I dont wanna deal with just to get the horn to work. My column the thin that sticks through the steering wheel is busted off because it wouldnt go in my wheel right, as well as now I have a 91 Airbag wheel on my car, and it doesnt have the horn contacts in it. 91GreenBird HOW DID YOU DO THAT?? lol I have extra buttons laying around and I wanna do this. I'll hide it pretty good, just gotta prove that my stupid horn works lol
Old May 7, 2005 | 10:36 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
hey man, the fuse for the horn is the acc fuse. when i had a short in my car, my interior light, cigar lighter, and horn didnt work. turned out i had a penny in the lighter!! i use it as a change holder but anyway..look at it see if its gone.
Old May 7, 2005 | 10:49 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Yup! The ACC fuse is missing! I just pop one in and horn works?
Old May 7, 2005 | 11:28 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
dunno how they did it but theres the button near one of the ac vents that is for the horn and has wires running into my dash to the horn, it looks really bad.
Old May 8, 2005 | 10:09 PM
Car: 1985 iroc-z
yeah, the acc fuse should be it if its not there. now ull have an interior light horn and cigar lighter....for the radar detector of course!
Old May 8, 2005 | 10:14 PM
Car: 95 Z28
no one knows how to wire the horn to a button?
Old May 9, 2005 | 04:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You'd have to dig out the horn wires from the column and just wire them to a button. There might just be one wire; and the other terminal of your button would go to the chassis for a ground.
--Wait, you've got a '91 airbag wheel on there? Why? Is the airbag still inside? If so, sell it on eBay and buy a Grant steering wheel; I think their cheapest nice-looking wheel is $40. Add the horn button kit for $20 and you have a much better looking wheel with a working horn.
Such as:
$43, http://store.summitracing.com/defaul...part=GRT%2D415
and
$13, http://store.summitracing.com/defaul...art=GRT%2D5640
I think the horn button comes with wires and everything, check with Summit first tho.
Old May 9, 2005 | 06:40 PM
Car: 95 Z28
I got the airbag one because i love the way it looks and feels I hate grant ones lol
It's more than just my steering wheel lack of horn buttons. Its that my column is missing pieces too
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
