Smog Questions
Old Jun 15, 2005 | 04:48 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Smog Questions
My car is due for the CA smog check at a TEST only site AGAIN. What are reasons to make my car fail i want to pass first time around here is what im going to do please add to my list if you can.
Run fuel injector cleanr in the gas tank
Clean the carbon out of the TB and spry some TB cleaner in with the car on.
New cap rotor and plugs
New O2 Sensor
New PCV Valve
New Fuel filter
Clean the air filters
Set timeing.
And change the oil
Go back to my stock chip for the test and get the car as hot as possible does this sound like everything i would need to do to pass. The bearings in my smog pump are shot but it still spins fine would that cause me to have any problems with smog like higher levels of something.
Old Jun 15, 2005 | 11:45 PM
KED85's Avatar
I haven't tuned my car since I guess 3-4 years now.
It only failed because emissions reading "showed no operational cat convertor" and at same time I knew to stick in new oxy sensor.
This Sunday I am going for my test only to pass.
Oh I also changed oil, too. It needed it.
IF I could use water (as gasoline LOL!) & pass, I'd be doing it!
Set timing when ya get there & then bump it back. You can go to 14* and not worry! I have it there!
Give me a shout if ya wanna come with me Sunday AM to Newhall. We can do testing same time! G0D! That's sounds weird!!
Old Jun 16, 2005 | 12:15 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Yeah, I'll be testing Karl's car, so let me know if you want to come over too, we'll see what we can do.
As long as nothing is modified or not hooked up, then I'll see what I can do for you. If it doesn't go, then I can at least give you an idea of what it looks like. You just have to remember that you heard what it needs HERE, not at the shop...lol. Long story.
Old Jun 16, 2005 | 12:19 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Something to check before you go is the EGR. If you have a vacuum pump, it's really easy. If you have an automatic then all you have to do is disconnect the EGR line from the EGR and hook your pump up to the end. then place it somewhere that you can see it from the driver's seat. get in and power-brake it. you should see a fluctuation in the needle. If not, there is no signal to the EGR. If you do, continue by hooking up the pump to the EGR itself and give it a few pumps, the engine should drop in RPM or stall. That means the EGR valve is working.
Old Jun 16, 2005 | 12:22 AM
FAST RS's Avatar
I have a digital EGR not a vacuume one i wish i did though cheaper to replace and i may need to repalce my EGR since i threw a code 32 the other day we wil see waht that smog ****'s have to say about that hopefuly i can get by
Old Jun 16, 2005 | 12:25 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
You forgot Plugs/Wires..
Old Jun 16, 2005 | 12:30 AM
FAST RS's Avatar
Wires are about 6 month old MSD wires so they are in good shape.
Old Jun 16, 2005 | 01:01 AM
FAST RS's Avatar
Im gonna go to the test only place right across the street from me its 39.99 plus the cert fee and tax.
Old Jun 16, 2005 | 01:57 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
A new three-way catalytic convertor and have the car running on the hotter side if possible will help the cat fireoff all polutants
Old Jun 16, 2005 | 02:15 AM
FAST RS's Avatar
Last time i took my car in it was running at 250-260 there is something wrong in the stock chip that does not kick the fan on until it hits 260 so i will be well heated up maybe too hot.
The Cat is about 3 years old it is a dynomax direct replacement. I am not sure how many chambers are in it though. It is a high flow i know that much.
Old Jun 16, 2005 | 09:02 AM
KED85's Avatar
I ordered mine as a direct fit for a 1993-95 3.4.
Magnaflow 23494.
Fit my 1985 pipe set up PERFECT! 2 1/2" in & out.
Old Jun 19, 2005 | 05:58 PM
KED85's Avatar
New Catalytic Convertor & new oxygen sensor &
no new plugs nor new cap/rotor
BUT fresh oil change
Equals
PASSSING SMOG!!!!!!!!!
Thanks 2point8boy!
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 7, 2015 09:55 PM
