Questions Galore
Old Jul 6, 2005 | 04:24 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
Transmission: 5 speed
Questions Galore
If i relocated my air filters, from above my radiator to in front of my grille, would it make ne difference in power or gas mileage? Or am I better off leaving it alone. If i were to change it I would do like a K&n cone filter and new piping so its getting direct air. Any thoughts?
Also....my exhaust is dying, I noticed my o2 sensor is before my cat, this means i can take off my cat and it wont affect my engine right? Emissions is not a problem, I dont have to take it here. And when i replace my exhaust, I kno Ive asked before, but what size should i go with, i kno my tip is 3inch thats how i bought it, it just seems to big to me.
what do you think would happen if i elimnated the cat and ran like 2 1/4 pipe back to a muffler?
Old Jul 6, 2005 | 04:46 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
you have the dual snorkel intake, leave it alone, grab some k&n's and gut the airbox, with our motors its better to leave the cat unless you have some serious mods done.
2 1/4 is the best size to go with for exaust
Old Jul 6, 2005 | 06:57 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
ok, if im leaving the cat, then should i go with maybe a higher flow cat?...mines pretty rusty and im sure its next to go. And how would one go about gutting the airbox? any pics?
Old Jul 6, 2005 | 07:13 PM
KED85's Avatar
There is NO reason to keep the cat unless it's a smogging place state.
That said
I'd go with 2 1/2" pipes
Some here have gone to three inch pipes with success, too.
Lucky you have a decent air inlet set up.
Try doing that air cleaner trick to a Firebird. Nope won't fit under the hood.
You want coolest outside fresh air into engine not hot under hood air!
2 1/2" pipe set up wil be most cost effective for you.
And honestly, just gut the cat & put it back, it makes a great perfect fit straight thru pipe!
Old Jul 6, 2005 | 08:46 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Take the filters out, remove the four screws to get the baffles out of your way, then just cut out the bottom. I got lazy and just removed the baffles and drilled a bunch of 1/2 inch holes in the bottom of mine.
Old Jul 6, 2005 | 09:40 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
and doing this wont mess nething up?
Old Jul 6, 2005 | 09:51 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Nope i compleatly cut the bottoms off mine all you see is the airfilter if you look at it from under the car.
Old Jul 6, 2005 | 10:18 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
and in doing this, what am I accomplishing? will I see gas gains or whatnot?
Old Jul 6, 2005 | 10:22 PM
FAST RS's Avatar
Just more air flow and i noticed more of a pull at higher rpms.
Old Jul 6, 2005 | 10:24 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
you probably won't see any gains with this, i did it, but now wish I hadn't. The thing that you have to remember is that these dual snorkel intakes cam on the 350 TPIs too. I figure that if they can flow enough air for a motor litterally twice the size of ours, they can more than outflow anything we can dream of with out A LOT of mods.
Everytime it rains I have to be careful going through puddles now that mine is empty because water splashes up there and gets the filters all wet...bad news.
Oh, and if you're gonna go through the trouble of removing the cat and gutting it, just completly replace it with a straight pipe. If you put the cat back on there, it'll become an expansion chamber, the exhaust will hit it, expand and cool, then it movers slower through the rest of the system.
Old Jul 6, 2005 | 10:26 PM
FAST RS's Avatar
I agree with you on that but i have not had any problems with my filters and water guess i have been luckey.
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
sweet thanks.
As for the exhaust, I think I will keep my idea of taking out the cat, and doing a 2 1/4 exhaust.....2 1/2 to 3 inches seems too big for such a small engine. I dont want a loss in backpressure. And if anything I'm looking for horsepower gains.
Old Jul 6, 2005 | 10:37 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Yeah, this last January when it was POURING out here, I was going down the freeway and popped on an O2 rich code because the filters got wet, stopped flowing and the ECM couldn't compensate enough for it. That sucked...my pour car was slower than it usually is.
Old Jul 7, 2005 | 08:55 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
the dynomax catback 2.5 in exhaust is a nice lil upgrade for our engines. 2.5 isnt too much at all for ours. you can run headers, catback and no cat and wont have any problems w/ backpressure at all. when i put my catback on i noticed a power gain too. i replaced my cat w/ a high flow convertor from catco. only a 1-2hp difference between that and no cat.
ive gutted my airbox as well, you pull the filters and can see pavement. i havent had a problem since i did it w/ water, but i havent really driven it a whole lot in the rain either. i also noticed a bit more pull in higher rpms when i did it.
Old Jul 7, 2005 | 09:10 AM
KED85's Avatar
The only reason I said gut the cat is
My previous CC was empty when I removed it.
The guts were already out. Placed at head of muffler!
That said, I was running an empty convertor for many months prior to recent installation.
I can't say performance was better or worse before or after I swapped in the new magno flow cat.
Old Jul 7, 2005 | 01:25 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
well ive heard many suggestions on size for exhaust, I will probably buy a set of pacesetter headers, and take out the cat.
But I'm lookin for a better sound...nothing too loud and I would like noticable power.......so you say 2.5 huh?
Old Jul 7, 2005 | 02:41 PM
drdave88's Avatar
Engine: 6.0L
most people seem to be happy w/ the dynomax setup for both sound and power.... and price
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
