Wow I'm a moron.
Old Jul 26, 2005 | 05:26 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Wow I'm a moron.
Upgrading the oil return line (from 5/8 to 3/4) and forgot I had a bulkhead connector on the back of the nipple, to keep it from falling out. Very tight, so I take a pair of vise grips to it, unscrew it, and hear 'ting'
Yeah, I dropped the bulkhead nut into the oil pan. Going to unbolt the entire pan, drop it down, and pray I can fish it out with a magnet!!
Any hope of this working?
Old Jul 26, 2005 | 05:29 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
shouldn't have a problem at all, just make sure to pick up a good magnet
Old Jul 26, 2005 | 06:01 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Doward-
Once was checking valve guide wear on a 3208TA Cat marine engine in a boat about 50 miles from the shop. I put the cylinder I was checking at TDC, and removed the valve keepers and spring with an overhead compressor. When I was done I'd put it back together, and turn the engine to put the next cylinder at
TDC. I did not have an adaptor to put in the injector hole nor an air compressor to hold the valves shut.
Can you guess what happened?
Yep- I turned the engine without putting the springs and keepers back on a valve.......CLINK!!!
Fortunately, the valve didn't fall all the way out of the guide, and it was an exhaust valve, so I was able to remove the exhaust manifold (water cooled, so I had to drain and collect the antifreeze) and I was able to use a needle nose pliars to guide the valve back into the guide as I turned the engine backwards
to push the valve back up so I could put the keepers back on.
And I got this all done re using manifold gaskets and nobody up until now knowing I did it. If had not heard the valve dropping, and kept turning the engine I would have had to pull the head to put it back together.
The moral of this story is everyone makes mistakes.
Old Jul 26, 2005 | 10:38 PM
catchmeifyoucan's Avatar
Car: 87blueracr
Engine: u know them
Transmission: u got it
doward, we all do things without thinking sometimes, the fact is that you did have a brain fart, and you didn't break something that you couldn't replace. with that being said everyone has brain farts, look at my last post to dean about the nose thing, i was having a terrible day, and my brain took a dump, the testosterone got the best of me, and i said something that was completely dumb, can't fix it now, but i messed up. i just had to go and get a new email and screen name.
Old Jul 26, 2005 | 10:55 PM
KED85's Avatar
16
I'm gonna look at the carb on my Corvette
Off comes the air cleaner
Clink!
I dropped the carb stud down the carb.....
That wasn't as bad as
16
I'm gonna align the door better on the 1954 Corvette
Out comes one screw
Out comes other screw & Dunk Thunk
Of course I separated the back half of the attaching plate for the striker!
And those famous words
"You better fix that before your Father gets home!"
You'll do much better at the repair without dropping the pan!
Old Jul 27, 2005 | 11:54 AM
Doward's Avatar
Driver's side oil pan bolts are out... oddly enough, 2 are missing from the oil pan... might explain that little leak I've been having!!
Oil is drained, as well. I'm not going to change the filter (less than 1000 miles on it) but I am going to change the oil itself. Might as well, you know?
Hotter than hell out there, though. So I'm going to wait a few 15 minutes, and go undo the passanger side (I hate that side... have to pull the starter to undo the bolts)
Then, here's hoping I can wiggle the pan down enough to grab that stupid thing with a magnet!
Old Jul 27, 2005 | 04:00 PM
KED85's Avatar
Shall I send the next hurricane your way with some cooling ocean breezes?
Great going!
Old Jul 27, 2005 | 08:55 PM
Car: 87blueracr
Engine: u know them
yea karl, it is hotter than a witches T** over here, but i am underway and i haven't seen more than 85 all day
Old Jul 28, 2005 | 08:06 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
doward, if you can't fish that thing out of there...unbolt the motor mounts and jack the motor up as high as you can get it. i've had to do that to get my pan out to change the gasket on it, before. not fun but it will clear. (incase you haven't done it before)
Old Jul 31, 2005 | 08:18 PM
Doward's Avatar
Pan is down, going to fish for the magnet in a few minutes... .IF I CAN FIND THE DAMN MAGNET NOW
Screw it. WalMart + 12:31 am + Doward = madness.
Old Aug 1, 2005 | 02:19 PM
Doward's Avatar
Doward + 3:30am = car is victorious.
Car now sits 2.5' in the air, and the pan is coming totally down.
Old Aug 1, 2005 | 05:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How big is it? Is it worth all that trouble?
I dropped a cam roll pin in the pan once and solved the problem by sticking a speaker magnet on it. Steel don't float and oil is thick.
Not like it was going anywhere. Part that big can't get inside anything important and just sinks.
Old Aug 1, 2005 | 08:41 PM
Doward's Avatar
Yeah, I know. I don't really have to go through all the trouble I'm putting myself through, but how stupid would I look if it somehow took out the crankshaft while spinning 6300 rpm down the track?
Gonna be a loooooong night ahead of me. *sigh*
Old Aug 1, 2005 | 09:20 PM
Car: 91 Camaro
yeah, that's what i was thinking. i would be worried about it bouncing up and getting into contact with the crank/rods.
Old Aug 1, 2005 | 10:56 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Well, since you have the pan off, you might see if you can fab up a windage tray just for fun.
Old Aug 2, 2005 | 12:22 PM
Doward's Avatar
I don't think I'll have it out long enough to do a windage tray
Starter is out... looks like I have a slow leak either at the back of the oil pan, or at the rear main seal (both are new ) I'll be replacing the oil pan gasket, but I'm not pulling this tranny until the V8 WC T5 is ready to go in! (A couple more weeks, lol)
Starter is out, Turbo is back out, exhaust is down. Oil pan is undone. Searching for my stupid 17mm wrench, so I can undo the motor mounts, now.
Old Aug 2, 2005 | 05:10 PM
Doward's Avatar
I got the stupid thing out. FINALLY. THANK YOU ALAN!!!
lol
He suggested I jack the front of the motor up, to get the pan down... my pan still won't come down, but it DID come down enough for me to get the nut out!
Everything's going back together again tonight!
Old Aug 2, 2005 | 05:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
glad to hear you got it out
Old Aug 2, 2005 | 07:21 PM
Doward's Avatar
Oil pan is DONE. Totally in, bolts are tight, new magnetic oil drain plug in (hey, I lost mine - so it was a good excuse ), oil return upgraded/finished.
And then the lightning started Storming now. Tomorrow will see the starter put in, the exhaust bolted back up, the BOV upgraded, and the turbo setup put back in.
Maybe I should time myself on the exhaust setup
*EDIT*
Yes, I could have left it in there... but I've always believed - do it once, do it right. My oiling system is not the place to half-*** something, right?
Old Aug 2, 2005 | 09:48 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
*EDIT*
better to be safe, then sorry
Old Aug 2, 2005 | 10:31 PM
Car: 91 Camaro
lol
no problem. get that beast back together...i still wanna race ya! lol
Old Aug 2, 2005 | 11:44 PM
Doward's Avatar
No kidding... still pisses me off that I'm only *officially* .02 seconds in front of you, when my trap speed is a whopping 11mph higher!!
Old Aug 3, 2005 | 07:48 AM
Car: 91 Camaro
lol. i kind of like it!
Old Aug 3, 2005 | 10:43 PM
Doward's Avatar
Hell, I don't!!!
New BOV is ready to be installed.
Exhaust is back up.
Storms are back
G'ville was rained out anyway
Tomorrow, SHE LIVES.
Old Aug 4, 2005 | 08:55 AM
KED85's Avatar
Leak?
Rear Cam Gasket up top. Dealer item.
You can fix that when you do install the other tranny.
Great going!
I gotta ask
"BOV"?
Old Aug 4, 2005 | 09:00 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Blow off valve
Releases excess boost when the throttle snaps shut, or for whatever other reason, so that the intake boots just don't pop right off.
Old Aug 4, 2005 | 09:09 AM
Doward's Avatar
Originally posted by KED85
Leak?
Great going!
I gotta ask
"BOV"?
Actually, CarQuest had one.. remember my engine rebuild? It honestly looks like the back of the oil pan gasket was leaking - and considering I had 3 oil pan bolts not installed, I can believe that
Old Aug 4, 2005 | 09:12 AM
KED85's Avatar
Thanks!
In INDY car Racing & Formula One Racing
That's called a
Pop Off Valve
Old Aug 6, 2005 | 12:49 AM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Doward=DowTard... bloke, you and i put the fail-safe jam nut in there... build an idiot proof mouse trap, and they'll build a better idiot... honky, im really hoping that since we got rained out, last week, that you and i can figure out what the F, and get shizzle going the the track. cuz if you can't run against a 15 sec TC, not only will i laugh at you, but i will publically post that you lost to a merely 14.7 sec stang, but a 15 TC as well.. with a turbo i built... so i fabbed it, you tune it.. lets get this shyte going...
Old Aug 6, 2005 | 02:13 PM
Doward's Avatar
Turbo's back in, exhaust is bolted up - changing around a little bit of the wiring, though. No biggie, all and all. I'll post pics of my battery cable later for you guys to gawk at
Intake tract to go back on, new BOV, then testing
Old Aug 6, 2005 | 04:21 PM
KED85's Avatar
Make the engine stronger than before
The it'll really be worth the effort!
Old Aug 9, 2005 | 02:59 PM
Doward's Avatar
Why do I deal with this car.
Had to replace the ignition lock cylinder (lost the keys)
Best part - now the starter seems to be toasted. When to crank, nothing. Did get a little smoke from the starter area though - but of course, it's f'ing raining AGAIN, so I can't pull it back down to determine the problem.
I did disconnect the battery though, just in case
Old Aug 9, 2005 | 03:07 PM
KED85's Avatar
Fusible link
Not sausage link
Or Jimmy Dean Links
Fusible link....
Especially if ya had that wonderful smell associated with the smoke.
Man, soon you'll be mad enough for that for sale sign......
Old Aug 9, 2005 | 04:36 PM
Doward's Avatar
Fusible link
Not sausage link
Or Jimmy Dean Links
Fusible link....
I'll check the links when I drop the starter (here after I eat)
For sale sign? Eh, not yet... still enjoy her too much
Old Aug 9, 2005 | 06:17 PM
KED85's Avatar
They are the wires right onto the solinoid.
I crossed battery cables on my Blazer
Hit the starter key
Sizzle
New fusible link & all was well.
My "operation" required extreme shrink wrap for max protection.
They have those links in "certain ratings" make sure you match what ya need.
PS Finding my "damage" was most easy, tho. You can't miss a burnt fusible link.....looks/feels just like a burnt sausage link in the pan...
Old Aug 9, 2005 | 06:30 PM
Doward's Avatar
No breaks in the links, good conductivity throughout... no burns, nothing.
Starter was locked up tight, though.
New starter came with shims... LOL, haven't used any shims before.. off to search on that
Old Aug 9, 2005 | 06:33 PM
KED85's Avatar
You can always do the on ground battery cable test.....
Shims are wonderful things......
All my cars do have them. All 5 of them....from 1967/68 example to the 1985s & a one 1974 thrown in for that in between period.
Old Aug 10, 2005 | 05:56 PM
Doward's Avatar
Ah, no track tonight. She starts, she runs (still working on that tune for part throttle) but 2 things verified -
I need to get more T-Bolt clamps
also...
My oil return is NOT returning appropriately.. it has a small low spot, that is causing oil to pool there. That will be fixed tomorrow.
Old Aug 10, 2005 | 09:55 PM
KED85's Avatar
I think it's great you are again this close to having your ride back to your liking.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
vortech305
Oct 30, 2001 08:25 PM
JeffC1500TBI
Oct 23, 2001 11:01 PM
Tom 400 CFI
Feb 9, 2001 04:36 PM
