Here is a good spring option for V-6 cars
Old Aug 15, 2005 | 03:04 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I looked forever for a good set of V-6 springs and finally decided to just get some non-engine specific 3rd gen springs and try them out. I used the Springtech set. At first the car was about level and 1/2-1" lower than stock. It wasn't bad. Then I installed the 200lbs of stereo in the back and the back end was about 1/2" lower than the front. So going against traditional wisdom, I cut the front springs one coil each, and here is the result. The car is about as low as I could comfortably drive on the street, it handles great, and I don't have any tire rubbing issues with 235/60/15's
(sorry for the crappy cam-phone pic)
Old Aug 15, 2005 | 03:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What do you consider a "good" set of springs?
Old Aug 15, 2005 | 03:51 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Something that makes the car look good, while still providing better than stock handling. Are there any other definitions?
Old Aug 15, 2005 | 04:05 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Dropzone V6 springs. Paid $115 shipped via Ebay.
Old Aug 15, 2005 | 04:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, okay. Because I have Suspension Techniques springs, meant for the 2.8/3.1 V6, cost me $180 from shox.com two years ago.
Old Aug 15, 2005 | 06:18 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I just ignored the naysayers of "You can't use those springs! They are for a V8 application" and bought Eibach Sportlines.
Here is a shot of the '91 RS along with my bone stock '88 Iroc Z, both cars have 245/50/16's on them.
RS corners like a go kart, rides a bit firm- the Iroc with worn out stock parts feels like Grandma's Buick by compraisson.
Iroc is a wee bit faster though
Attached Thumbnails Here is a good spring option for V-6 cars-iroc-rs-right-side.jpg
Old Aug 15, 2005 | 11:38 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
did you cut the sportlines in the front? i was looking at them over the pro's, if i were to go eibach. otherwise id get the st or dropzone springs. although if i can get 4 dropzone's for $115 like doward, thats pretty hard to turn down. i just want some fairly hardcore springs, i dont really give a **** about ride quality. i may just eventually figure out some spring rates and all that gob and just get "custom" springs or something(custom as in not some tailored package deal like eibach "pro" or "sportline").
as long as i can stuff 245/50/16s under it, ill find some way to deal with ground clearance.
Old Aug 16, 2005 | 05:45 AM
Car: 3
Engine: inboard
Nope, did not cut anything. Left out the rear isolators.
Old Aug 18, 2005 | 05:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you get any grinding noises from the back?
I'd heard of guys slipping pieces of garden hose over the ends of their springs to prevent the metal-on-metal contact when they removed the isolators... I thought of doing that on my front springs, then I saw how thin the stock isolators were and just left them in. (I bought new front isolators)
Old Aug 18, 2005 | 06:24 PM
Car: 3
Engine: inboard
Tom, if they are I can't hear 'em over the groaning from the poly bushings I put in without greasing. I'll not make that mistake again.
midge54
Sep 2, 2020 07:13 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Linson
Aug 21, 2015 02:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
Amillionoh7
Aug 7, 2015 01:24 PM
