How do you turn the crank?
Old Aug 16, 2005 | 04:31 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
How do you turn the crank once you have taken off the timing cover to reach TDC? what do you use to turn the sprockets so they can line up for TDC?
Old Aug 16, 2005 | 04:48 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
That's why I line up TDC #1 BEFORE pulling it apart
Old Aug 16, 2005 | 06:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
line it up before hand, i however used the crank bolt to line it, a severe no-no but it had to be done
Old Aug 16, 2005 | 06:59 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I put the harmonic balancer bolt back in the end, with a socket to take up the space of the balancer. Can use alot of washers, but the socket was faster to me.
Old Aug 16, 2005 | 08:24 PM
DeanE's Avatar
Pull the spark plugs so you relieve compression and then just place the balancer onto the end and spin it by hand using the balancer (doesn't even have to be bolted on, just the keyway.
Old Jun 8, 2006 | 04:13 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Old thread, but.....
how do you know its at tdc without seeing the timing chain or pistons....?
Old Jun 9, 2006 | 06:09 AM
Dale's Avatar
Engine: 350 S-TPI
balancer or dizzy.
Old Jun 9, 2006 | 03:25 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if the chain is still on, the marks on the sprockets will line up. if its off, then put it back on to set it at #1 TDC.
Caspar
Jun 19, 2016 11:19 PM
Justin69
Aug 31, 2015 11:31 AM
WIzmo
Aug 30, 2015 02:30 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
