need help figuring out a few parts for the 3.4
Old Aug 24, 2005 | 11:04 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'm currently ordering parts, and wondering where
i could get a good set of high quality pistons
and if anyone had a link for the 1.6 crane gold rollers rockers and pushrods.
i'm having problems finding things
heres a list of what i have planned, any suggestions or tweaks would be aprreciated
1994 3.4 block bored jst enough to clean up the walls
reground crank
clevite main and rod bearings
melling mtc-5 cam
profesionally ported and polished stock heads, 3 angle valve job
brass freeze plugs
melling hi volume oil pump
cloyes double roller timing chain
crank under drive pulley
crane 1.6 full roller rockers
crane pushrods
accel 17lb injectors
afpr
mallory distributor
oil filter reloaction kit
stock oil pan
headers
new cat
still need to choose springs, and figure out a new plenum
haven't figured out which springs i should go withblock and heads go in end of september to get machined, need to get the rest of these parts ordered before then
Old Aug 25, 2005 | 01:36 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
www.ftpp.com has some ross pistons . . . dome flat or dished, although you have to call them to get the exact specs. check there. i think they have forged pistons at like 485 grams a pop, or 560 or 580 for boost or nitrous.
i dont know for sure, but depending on how much your flowing with the heads and cam you may want 19# injectors. I know dale said recently that he found that part of the high rpm problem with our motors is the injectors, im pretty sure if you are increasing the airflow more im think you'll want 19#'s.
are you planning on keeping stock compression ratio? .
Old Aug 25, 2005 | 12:48 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
(LT1guy)
The Fierostore
http://www.fierostore.com
has lots of stuff for the V6s in stock. Ross does make the pistons, but be warned they are not cheap-prob in the $600 range-but they are great quality. They did the forged flattops for Shannon's 512 CID Caddy motor (using Eagle Olds rods), and they are some of the nicest pistons I have ever seen.
Old Aug 25, 2005 | 01:03 PM
wildponies3's Avatar
Car: 87 camaro(Temporary insanitee)
Engine: 2.8
Transmission: Non worldclass t-5
did you think to get a set from anderson racing???
(ari)
Old Aug 25, 2005 | 03:49 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
ari gets there pistons from ross for the 3.4, i get my set from them
one of these days ill finish that motor, powdercoating it all right now =)
Old Aug 25, 2005 | 09:06 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i'm hoping to keep compression as stock as possible, as far as injectors go, i'm holding off buying them for last, i'll figure out exactly how much air i'm flowing adn go from there, if i have to go to 19 i will.
whatevers gonna work best
Old Aug 25, 2005 | 09:07 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Originally posted by redraif
(LT1guy)
The Fierostore
i figured it owuld be around 600 for a good quality set, this motor is not something i'm willing to cut corners on, i want it to be a very stout little 3.4 that will last for a very long time
Old Aug 25, 2005 | 10:03 PM
Naft's Avatar
while youre calling ftpp for the ross piston specs, want to write them down and post them here?
good plan.
im starting to put aside $ now for a total 3.4 build, although im planning on going a little more radical than you, but i also wont be dont for a lot longer than you, especially if i try to wait around for an aluminum block with 92mm bores instead of 89mm
Old Aug 25, 2005 | 10:07 PM
Pillsbry10's Avatar
mine through ari were like 680 or 690, and they are ross pistons
Old Aug 26, 2005 | 12:04 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
good plan.
i'll definatly get the specs off them
like i said earlier, i'm not planning on having the fastest 3.4 out there, but this motor will be a very quick little 6.
although i've started ordering parts and such, and while i'm getting the machining done, this motor will not be assembled for a while, i'm planning on doing it very well, and waiting for a few aftermarket parts to come out.
i believe this motor will also accept boost very well, my eventual plans are to turbo this, this is why i'm not going to fully assemble the motor for a bit.
hopefully someone on this board will get an intake done, and still be making the turbo kits when i have enough money to get it
Old Aug 26, 2005 | 02:19 AM
Naft's Avatar
i'm with you on the slow and complete build, if youre going to do it, do it 100% the first time around.
i wish i had the option of turbo in cali, but i need to make this so i can covert back to smog legal with little downtime. i figure im gonna milk all i can out of it n/a and then maybe custom fab a blowthrough s/c that i can take on and off(a helluva lot easier than replacing the exhaust, etc for a turbo) if i need more power. this will be more of a roadrace/autox car like dean's though, so i dont need v8 power.
one thing i am looking at doing is my own intake work(depending on what doward and the others come out with). think it would work to make an upper intake eintirely out of jb weld?(from a mold or cast or something). lol probably not, but it'd be sweet to have a jb weld plenum. it'd get rid of those nasty bends at least.
Old Aug 26, 2005 | 09:49 AM
Engine: 2.8
as said, pistons are a little more than 680 for custom forging of them..... that is where i am getting the 11.5:1 pistons for the 3.3 stroker i am building, but the difference is i am building it while in the car, and keeping down time to a minimum!!!! pulling engine once to do the bottom end. the rest will be done with the engine in the car.......
have fun
Old Aug 26, 2005 | 11:33 AM
Pillsbry10's Avatar
mine are custom forged pistons made for a .30 bore and 9.1 compression(in intrest of maybe turbo one day)...found the bill 680 exactly
Old Aug 26, 2005 | 03:49 PM
Engine: 2.8
i'm going .01 less than max, with the 11.5:1 and a race cam. should boost me up even more than what i got more. i will prolly get another set later for like 9:1 compression when i go forced induction.
long story why i am building it this way now, then turning to forced induction later!
Old Aug 26, 2005 | 08:01 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
this is exactly what my car is getting built for, daily driver/ weekend auto cross
Old Aug 27, 2005 | 03:30 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
should i get a bigger throttle body?
Old Aug 28, 2005 | 11:20 AM
KED85's Avatar
Northern Auto parts
800-831-0884 or www.northernauto.com
I see your location and yes you can be sent the stuff over the border.
They advertise in lots of publications.
Great prices.
Old Aug 28, 2005 | 01:22 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Originally posted by KED85
Northern Auto parts
Great prices.
it should be northernautoparts.com
but thanks for the link, they seem to have some damn good prices
Old Aug 28, 2005 | 08:53 PM
KED85's Avatar
They are a GREAT OPTION
I got from them the TRW stuff to build me a LT-1(1970)/Z-28 engine.
Great option for engine parts and yes very fair prices..
You enjoy the project!
IF YOU CAN upgrade to the "beehive" valve springs from Crane or Comp cams.
Stronger & less weight for stronger revs.
Old Aug 28, 2005 | 09:19 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i've already looked into them, i have to call crane to see if they make them
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
