Is it hard?
Old Aug 25, 2005 | 11:52 PM
earlesimers's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
Is it hard?
Is it very hard to change the valve cover gaskets? Do I have to have any special tools before I start? Can I do it in my apartment's parking lot without too much trouble?
What about taking the entire carpet out? Mine was damaged by water I need to get it out, its already starting to mold, and it really smells bad.
Old Aug 25, 2005 | 11:56 PM
Car: '91 Camaro RS
Engine: 3.1 V6
here is a pic of the water coming in on my car!!
Old Aug 26, 2005 | 12:00 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
is that a photoshop pic?
Old Aug 26, 2005 | 12:02 AM
Car: '91 Camaro RS
Engine: 3.1 V6
NO!! just my logo on it. I have more if you don't beleive me! lol
Old Aug 26, 2005 | 12:10 AM
Car: '91 Camaro RS
Engine: 3.1 V6
this is after the water went down, see the water standing in the floor-board, and my cd-case floating LOL!
Old Aug 26, 2005 | 12:15 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
carpets not really hard, just time consuming, i'd be sure to air the car out when you pull the old carpet
Old Aug 26, 2005 | 01:08 PM
Car: '91 Camaro RS
Engine: 3.1 V6
what a about the valve cover gaskets??is it too hard to do in a day? special tools?
Old Aug 26, 2005 | 01:40 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
No, only really hard part, is depending on the car, getting those damn valve covers off Me with big hands have a bit of a fight on my hands. Anyways, just scrape the old gasket off, and put a new one on, nothing to complecated.
Old Aug 26, 2005 | 01:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'd guess Florida? For the carpets start by removing the door sill plates. Lift the carpet there and see what else is in the way. The carpet can usually be pulled out from under the kick panels. Console needs to come out.
Not sure but you may need to pull some of the seat rail mounting bolts. Sometimes the carpet has an opening for the seat foot, other times the carpet is cut to clear.
If the valve covers have studs then the upper and middle intake has to come off. The valve covers held in place by bolts usually clear the middle intake (this info is from what others have posted here).
RBob.
Old Aug 26, 2005 | 01:45 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Holy ****!
Post more!
Old Aug 26, 2005 | 02:10 PM
Car: '91 Camaro RS
Engine: 3.1 V6
Originally posted by V8 Slayer
Holy ****!
Post more!
pics? will do. when I get home, at work now. I'm not from florida. I'm in Missouri. Had a big rain storm this past Sunday.
Old Aug 26, 2005 | 02:14 PM
Car: '91 Camaro RS
Engine: 3.1 V6
Originally posted by RBob
.......If the valve covers have studs then the upper and middle intake has to come off. The valve covers held in place by bolts usually clear the middle intake (this info is from what others have posted here).
RBob.
can't remember have to look. thanks for that info. if I take the intake off will the gaskets there need to be replaced as well? my father alway told me to do that, (if you take it off put a new gasket back on) he said there is too much of a risk there. also is the chilton's book better than the haynes? cuase i have the haynes, i don't like it.
Old Aug 27, 2005 | 04:54 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
wow, you need a better parking space.
Old Aug 27, 2005 | 11:16 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
the hardest part about taking out the interior was the seatbelt posts. you may need airtools. other than that it wasnt too hard. just took a long time. like the center console.
what kind of damage other than mold would that do?
Old Aug 28, 2005 | 01:13 AM
Car: '91 Camaro RS
Engine: 3.1 V6
Originally posted by 85berlinetta2.8
........what kind of damage other than mold would that do?
you mean the water? well did 1300$ worth of damage to the whole car. 1000$ of that was motor/electrical, sensor and stuff like that.
I have no air tools.?? i attepted to take out one of the bolts that holds the seatbelt in on the front passenger side, and well to make a long story short, I'm leaving it be. my belt will just have to be blue for now. can't get it to turn.
Old Aug 28, 2005 | 01:20 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i had no problem cracking them, might be the fact i'm a pretty big guy, but no problems at all
Old Aug 28, 2005 | 06:41 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
1/2 inch breaker bar does wonders for them bolts.
I actually broke the socket (torxs bit same diff) on the drivers side thank *** matco has warrenties.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
