Valve Covers Help Fast!!!
Old Sep 3, 2005 | 02:28 PM
earlesimers's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
ok, yes i have searched for the answer but its still not clear to me. Can I or Can I Not change the Valve Cover Gaskets WITHOUT taking the entire Plentum off? If I can then I am missing something here, cause I can't even see the bolts/studs that hold the inner side of the cover?? by the way my car is a '91 3.1 v6 with A/C. Help Fast please.
Old Sep 3, 2005 | 07:47 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
nope
Old Sep 3, 2005 | 09:06 PM
Car: '91 Camaro RS
Engine: 3.1 V6
Originally posted by Project: 85 2.8 bird
nope
This sucks! what a crappy design! I just don't trust myself on taking all that stuff off. I figure I would have to take the whole plentum off not just the top half, plus all those wires/hoses, throttle body, and who knows what else, plus won't I have to take the fuel rails out too? I don't know about this guys it may be too much for me to handle?? does anyone have any pointers on doing this maybe pictures? I have a haynes manual but its not clear enough for my hillbilly mind. I need to do this because its leaking so bad, plus all the mechanics wanna charge me $300 or more to do this job.
Old Sep 3, 2005 | 09:24 PM
Engine: 5.7 / 7.4
what part of the holy book haynes do you not understand?
Old Sep 3, 2005 | 09:29 PM
Car: '91 Camaro RS
Engine: 3.1 V6
well in chapter 4 its supposed to tell me how to take the plentem off but I just don't get it. do i have to take the fuel rail out? do i really have to do all this just to get to the damn vavle covers??? I guess what i am looking for is a step by step instructions on "how to change valve cover gaskets on a '91 v6 3.1 camaro!" if its out there please direct me to where its at cause i really want to do this, i guess i'm just scared i will do something wrong, this is my only mode on transportation so it must be running tuesday morning so i can go to work.
Old Sep 4, 2005 | 12:54 AM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
the fuel rail will have to come out. The coil has too come off too
Old Sep 4, 2005 | 01:31 AM
Car: '91 Camaro RS
Engine: 3.1 V6
doesn't that envolve releaving pressure on the fuel system? how is that done?
Old Sep 7, 2005 | 08:36 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
youll have to pull the upper plenum off, t/b can stay on, just disconnect and remove anything attached to it or in the way to get it off. pull the coil bracket off, bleed off the fuel rail at the schrader valve on the back of the rail, pull the rail off, then the lower plenum. now pull the valve covers off. i had to pull the dist out to get the intake manifold off. now pull the intake off. reverse order and youre good to go. you DO NOT have to pull the push rods, you can cut the parts of the intake gasket off that goes behind the push rods. i made that mistake my first time, just wastes time and you take a chance at not readjusting them correctly. now reverse your steps, and youre all done. oh dont forget to replace the o-ring on the distributor, or youll have to do it right after.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
