3.1L V6 cooling fan switch
Old Sep 9, 2005 | 07:49 AM
92Firehawk8806's Avatar
Car: 1992 Pontiac Firebird
Engine: 189ci 3.1L V6
Anyone know where to find a cooling fan switch for a 3.1L? Or does anyone know what I'd need to make my own?
Old Sep 9, 2005 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No fan switch it is ECM controlled. Check out the tech articles for how to setup an adjustable switch.
RBob.
Old Sep 9, 2005 | 08:08 PM
Persanity's Avatar
Car: 1987 Camaro
Engine: 2.8 soon to be 3.1 Twin turbo
Axle/Gears: No idea ATM
since my engine swap, my fan always runs if the power is on, im thinking the previous owner did something as i used the replacement engines wiring harness and not my original
Old Sep 9, 2005 | 08:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the A/C pressure switch was removed it will cause the fan to always run. If so, ground the pressure switch wire that goes to the ECM. Or wire it to a cabin switch to force the fan on when desired.
RBob.
Old Sep 9, 2005 | 09:04 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
RBob.
All my ac sensors are not plugged in and my fan does not come on when I start the car??
Old Sep 10, 2005 | 12:29 AM
Persanity's Avatar
Car: 1987 Camaro
question or statement? and maybe try pluggin it back in?
Old Sep 10, 2005 | 08:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Bad ECM? Non-stock chip?
RBob.
Old Sep 10, 2005 | 10:07 AM
Dale's Avatar
Engine: 350 S-TPI
I've had it on two different ecms(auto and manual), did same with both.
Both ecm's are completely stock.
jhawkeye
May 25, 2022 06:33 PM
jutt26
Jul 11, 2004 05:41 PM
Dale
Jul 31, 2002 01:18 PM
elevario
Aug 28, 2001 03:34 PM
