v6 Bore
Old Sep 19, 2005 | 09:10 PM
TransAmMike's Avatar
Car: 91 Firebird
Engine: 3.1 v6
Transmission: Automatic
v6 Bore
What's the most you can have the 3.1 v6 bored out to?
Old Sep 25, 2005 | 12:47 PM
Car: 91 Firebird
Engine: 3.1 v6
Anybody know? I'd like to find out BEFORE I buy the pistons.. don't wanna find out that I got pistons that are too big.
Old Sep 29, 2005 | 12:39 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
bump this
Ide also like to know !! can any one out there tell us?
OH and also i was wondering .,If once bored out,. will it make it run hotter??thus needing upgraded coolin system??
Old Sep 29, 2005 | 11:19 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Your engine will run hotter due to the fact that the piston walls are gonna be skinnier. Dont kno how much hotter but I know it will run hotter.
Old Sep 29, 2005 | 12:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I belive .030 is max, 010 is most commen.
I know it cant be bored out to make a 3.4, walls are to thin.
Old Sep 29, 2005 | 08:07 PM
v6#21's Avatar
Max you can go on a 2.8 block is 3.56" bore. Standard bore is 3.50 so its safe to .060" over. 3.57" is getting very questionable.
The 2.8 and the 3.1 are "both" considered 2.8 blocks
The larger and stronger webbed 3.4 blocks can safely go to also is .060" over bore. The 3.4L blocks have a factory bore of 3.62" so you can go safely up to 3.68"
Old Sep 29, 2005 | 08:17 PM
v6#21's Avatar
And in cause anyone is wondering what the displacement is?
2.8L stroke/motor bored out to 3.56" = 2.97L
3.1L stroke/motor bored out to 3.56" = 3.3L
A 3.4 taken out max bore to 3.68" = 3.52L
A stock 3.4 is actually only 3.39L from the factory at 3.62" bore
Old Sep 29, 2005 | 08:23 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
so how long before you get this one banned?...
and tech...
.060 over is about it on all engines...
most do .020 incriments.
Old Sep 29, 2005 | 08:30 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
and tech...
QFT!
Old Sep 30, 2005 | 10:01 AM
V6sucker's Avatar
Engine: blown up
Originally posted by The_Raven
QFT!
Old Sep 30, 2005 | 10:04 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
There's no need to take your block that big. I mean, for a few ci, I'll trade that for reliability, and the ability to rebuild AGAIN down the road if need be.
I'm going .50mm on my block (minimum to clean it all up again) which is around .020"
Old Oct 1, 2005 | 10:10 AM
The_Raven's Avatar
QFT!
(Quoted For Truth)
Old Oct 3, 2005 | 03:32 PM
Car: 91 Firebird
Engine: 3.1 v6
Sweet thanks. And what all needs to be replaced once the engine is bored? Just the pistons or would i need like rocker arms and what not?
Old Oct 3, 2005 | 06:25 PM
V6sucker's Avatar
Engine: blown up
a rebuild kit will contain the larger pistons and rings and everything else needed.
Other than that, you will need to inspect everything else.
I will not say that everything needs replaced, but a few things, sure.
Old Oct 6, 2005 | 08:16 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Just my two bits, but I bored my 2.8 out .060 and put a 3.1 crank in it. The machinist had no problems finding the overbore pistons.
If you are going through all the hassles of rebuilding a 2.8, make sure you put the high flow oil pump in. It will give you lots more oil pressure at idle. So far I have 5000 miles on my new motor, woot woot! I got my complete kit for under $400 bucks with a bigger cam through delta cams here in Spokane Washington.
Old Oct 6, 2005 | 10:20 PM
The_Raven's Avatar
Only use a high pressure oil pump if you are also running something that needs an oil feed, such as a turbo.
I have known a few cam bearings to get damaged in these engine when using a high pressure pump.
Old Oct 6, 2005 | 10:25 PM
V6sucker's Avatar
Engine: blown up
yeah, high VOLUME is one thing that just about every motor could use, high PRESSURE is a No No unless the motor was BUILT for high pressure.
Old Oct 7, 2005 | 11:50 AM
Blue1989RS's Avatar
Car: 1989 RS
Exactly. In 1990 chevy put a new, higher volume oil pump in the 60*V6, GM part number 10051104. It got me about 10-15 more lbs of pressure at idle, according to the stock oil gage. Make sure you get that when you rebuild the motor. Other than than, balance the rotating assembly since you have it all apart and enjoy!
Old Oct 7, 2005 | 12:03 PM
Dale's Avatar
Engine: 350 S-TPI
Blue1989RS
Welcome back T. Where the hell you been?
Give me a shout when you get some time.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
hartsmike
Oct 2, 2015 07:11 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
