Fuel pressure regulator
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
How much power could be gained by installing one on my 2.8? Does anyone know wich one is best if any.
Car: 1987 Trans Am
Agreed, not much, but if you have a need for an adjustable regulator the Holley one is pretty nice. I don't have the part # handy, but its the one listed for TPI V8 applications.
Well #23 im guessing you have one?? lol was it worth it??
Car: a car being parted out
Engine: blown up
Transmission: in peices
Originally posted by V6#23
I gotta laugh again at the nonsense replies here.
It did wonders for me up on top end. Definately an improvement. But those that have not ever tried it are first to respond and tell you no from their *expert* hands on knowledge
Please. And do not come back.
Engine: blown up
I consider you to not be an "expert" on anything other than irratating people.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Originally posted by dodger65
if it's the stock motor and it's still fuel injected... you already have one...
Yea I was talking about fuel injected.. Sorry bout that
Car: 1987 Trans Am
I for one wish you and V6 sucker would take your pissing matches elsewhere. The good info sprinkled in with both of your posts are hardly worth the constant namecalling and bs that both of you spew at each other.
Car: 1987 Trans Am
Originally posted by V8 Slayer
Stock pressure is like 40 lb's right? What do you bump it up to usaually on a mild bolt on car?
Engine: blown up
Normal idle pressure is @ *Post removed* and full throttle psi shouild be around *post removed*
Signed, *post removed*
Gee, that was helpful, wasn't it. Lets see if anyone else here can give the correct #'s, because all answers so far are booksmart hearsay and not real world accurate yet.
69 charger, I'll email you privately, these guys are *post removed*. I could give a crap what my car does on a dyno, dyno #'s don't win races. My car does.
And you also know what? Books are right too. They give specific ranges, that are called "limits and standards". That means that it should fall in a certain specific number range, if it does not, something is wrong and needs replaced.
But you are right about one thing, no dyno numbers do not win races, but they are useful when tuning an engine. After all, if you adjust your pressure up, or down (like you might do for larger injectors), you would not be able to tell if it si helping or hurting unless you got on a dyno to check. That is unless you trust that stupid dash G-tech POS and use that to tune with...
Engine: blown up
Lets see... I stated above that the afpr did wonders for me.
What that means for the person challanged above me...it is a noticiable difference in improvement. What *noticeable improvement * means? It means I have to come into here and list this 18 times in black and white that I could easily feel and tell the difference when I adjusted it up and down. I do not need a dyno to tell the car is running stronger into higher rpms when I turn the pressure up, and then it falls on its face power wise when I turn it back down to normal.
Gee, that was hard to figure out V6 sucker. I have never bought a G-tech meter in my life??? Kid, I am well above your league. You have no comprehension you back woods hick. You want to keep posting crap and antogonise me bvack into here each time to respond? This is the crap the moderators need to weed out yet they ban me for responding and correcting crap, go figure. And as for the # of times I have been banned, there are many moderatorss on here that like me and want me around, and then there are the few here on the V6 board
that have a hard-on for banning me.
LT1 or V6sucker, why not both of you come over to one of these other posts I have made recently helping people and shoot your mouths off their about me, see what kind of response you'll get, or what kind of help you can offer? Didn't think so.
https://www.thirdgen.org/techbb2/sho...hreadid=329721
https://www.thirdgen.org/techbb2/sho...hreadid=329176
https://www.thirdgen.org/techbb2/sho...hreadid=329093
https://www.thirdgen.org/techbb2/sho...5&pagenumber=2
that have a hard-on for banning me.LT1 or V6sucker, why not both of you come over to one of these other posts I have made recently helping people and shoot your mouths off their about me, see what kind of response you'll get, or what kind of help you can offer? Didn't think so.
Maybe because everytime you post in the V6 forums, you are calling names and being abusive.
And as far as the "V6" mods "have a hard-on for banning you" maybe the others should take a look at what you do here, and then they would certainly see things the way we do. They would see your true nature of being an attention seeking, egotisical *****.
I will actually go one farther from just reporting this post, I will also bring it to the admins attention how you have now moved on to calling moderators names for doing their job.
Not to be an A$$ or anything but your basically gonna tell on him? I dont see any point to you guys arguing. One says one the other says something else. Its all opinions, dont argue over whos opinion is right. #23 you car prolly had a better reaction due to your less rotating mass, you others that have tried it or maybe not im not sure do you have mods to your cars or did you just slap it on there thinking it would add power? Again not being rude or anything just asking. Dont fight over worthlessness, just give your opinion or if possible a proven fact. Thanks, Baron
9192camaro
16
Feb 3, 2019 12:21 AM
