Starter or what?
Old Nov 1, 2005 | 06:59 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
Starter or what?
I just got off work and put the key in the ignition. NADA. The engine did'nt even turn over. The starter did'nt even make a sound at all.. I checked the fuses the first thing and they all looked good. When the key was turned to the RUN position all the gauge lights came on and showed a good charge on the battery and the fuel pump kicked in. I'm thinking it might be the key cylinder switch. I was wanting to short the "S" terminal on the starter to ground to see if it started turning the flywheel. but I was running out of daylight. If I short it and the engine turns over, prob the key switch. If the starter does'nt do anything after I ground it , then maybe bad starter. Anyone ever have this problem? Any advice?
Ken
Old Nov 1, 2005 | 07:39 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Re: Starter or what?
Ken
You could have a bad ignition switch, a bad relay or a bad starter selinoid.
To determine what, you need to break out a multimeter and trace wires.
Old Nov 1, 2005 | 07:41 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
doesn't the vats cut out the starter on them later cars?
Old Nov 1, 2005 | 07:46 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
.....yup.......ask me how I know
Old Nov 1, 2005 | 08:06 PM
ken3983's Avatar
When you say ign. switch...do you mean where the key goes into or a switch located somewhere else other than the steering column? How much of a pain to replace the key cylinder switch if thats it?
Ken
Old Nov 1, 2005 | 09:05 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I just had the same problem and for me it was the skirts or something inside the starter. They were completely worn out. I didnt even get a click sound or anything when I turned the key in mine so mybe the same for you?
Old Nov 1, 2005 | 10:52 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Just get a new starter. Silenoid is bad and you can get them just as cheap with a lt warranty from AZ.
Old Nov 2, 2005 | 08:56 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
I kinda have this problem with my car, but my problem is the computer thing on the key. 90% of the time it will start right up, but the other 10% it won't do anything when I turn the key. Adjusting the steering wheel seems to make it work if I have the problem. I don't see how that works, but it does lol.
Old Nov 2, 2005 | 08:59 PM
Engine: 5.7 / 7.4
there are 2 wires leading to teh key lock cylinder. sounds like you either :
a) take it apart & try to fix
b) take it apart & replace keylock cylinder
Old Nov 3, 2005 | 06:29 PM
V6sucker's Avatar
Engine: blown up
or have a chip burned removing the VATS.
Old Nov 3, 2005 | 08:27 PM
Engine: 5.7 / 7.4
some of us have parts that don't require a chip burned
but then , some of us don't have a need for them any more either :/
Old Nov 3, 2005 | 10:40 PM
Doom Sayer's Avatar
So you don't need the chip on your key?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
