Flywheel/flex plate differences...
Old Nov 29, 2005 | 04:39 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Is there a difference between the flywheel on an firebird 87 2.8 automatic and an 89 camaro 2.8 5 speed. After swapping motors I get a very noticeable vibration at the tranny. I used my 87 flywheel on the 89 motor. Anyone?
Old Nov 29, 2005 | 06:19 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
There is a huge difference between a flexplate and a flywheel.
But in regards to your underlying question, there is no difference in balacing between the "87 and '89 cranks, at least there's not supposed to be. The '87 MY was teh first year of the internally balanced 660.
Old Nov 29, 2005 | 07:51 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
89 as far as I have read, is the cut off year. Part year was internal, part year was external.
Even if both are internal. That 87 plate/wheel was balanced per the 87 crank, not the 89.
Old Nov 30, 2005 | 12:16 AM
The_Raven's Avatar
Change from small journal to large journal was a mid year change, internal/external balancing was at the beginning of the MY.
Besides, with both being internal, the flywheel/flex plate won't care what year crank it's on. The flywheel/flexplate will be nuetrally balanced, in both cases.
Old Nov 30, 2005 | 01:46 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
IIRC 1988 was the year of the switch to the internally balanced crankshaft. The symptoms describe also fit a misbalanced flywheel/flexplate perfectly. Unfortunately this mistake will have already dealt its damage to the new engine; expect a reduced main bearing service life. Replace the flywheel/flexplate with a neutrally balanced unit before starting your car again.
Old Nov 30, 2005 | 01:48 AM
TechSmurf's Avatar
Engine: LS1, Scrap
This would make no difference. Internally balanced engines use neutral balanced flywheels/flexplates. The definition of neutral, fortunately, is not particularly capable of changing from year to year
Old Nov 30, 2005 | 06:35 AM
Dale's Avatar
Engine: 350 S-TPI
ops, I meant external on that post. As well, if he put it back on the same engine, but wrong clock angle, same problem.
Old Nov 30, 2005 | 03:42 PM
The_Raven's Avatar
Yes, but then you'd have to drill out a few holes so that you could get the bolts to line up. The bolt pattern in the (even neutrally balanced) crankshaft is not a perfectly spaced cicurlar bolt pattern.
Also, it's my understanding that the entire 660 line up changed to the internally balanced design, with the introduction of the genII which was in 1987.
The symptoms do indictae a similar problem, but I have seen this happen even with the proper flywheel/flexplate. IIRC it turned out to be an ignition module or something screwy like that.
Old Nov 30, 2005 | 10:40 PM
sixbanger's Avatar
Whats the easiest way to get the plate off the back of the motor (without taking the motor out of car)?
Old Dec 1, 2005 | 06:33 AM
Dale's Avatar
Engine: 350 S-TPI
pull the trans.
Old Dec 1, 2005 | 04:57 PM
The_Raven's Avatar
pull the trans.
QFT!
Old Dec 2, 2005 | 06:36 AM
Dale's Avatar
Engine: 350 S-TPI
Originally posted by The_Raven
QFT!
Old Dec 2, 2005 | 06:45 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
https://www.thirdgen.org/techbb2/sho...61#post2643261
Old Dec 2, 2005 | 10:05 AM
The_Raven's Avatar
I guess that works, but it's actually Quoted For Truth.
Old Dec 4, 2005 | 04:28 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
That's what that post says at the very bottom.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
