Still car problems, but I see a trend
Old Dec 20, 2005 | 09:21 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, still having car problems, really really pissing me off. Car is now driveable outside my neighborhood again so atleast I can really drive it.
As the engine warms up, it tends to run better(still sputter, but not as bad and higher in the rpm range).
Airflow:
filters are good, no intake restrictions
exhaust, full flow no restrictions
compression is even
valves are set
Spark:
all has been replaced except engine ecm, and pickup coil(it ohm tested good)
Gas:
I think my injectors may be plugged, and debris still in the tank as that filter was freakin nasty. I am not dropping the tank in this weather though.
Sensors:
o2 still reads high
I noticed, tunerpro doesnt show the IAT/MAT. So this may be sending a wrong signal saying the air is really colder then it is causing ecm to dump in more gas? Everything else is either brand new, or turnerpro says is fine.
Old Dec 20, 2005 | 12:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
wher'd the bad gas come from? but maybe a fuel system flush/cleaning?
Old Dec 20, 2005 | 07:44 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
When I got my injectors cleaned all the sputtering and jerking went away, it was most noticible at highway speeds and very random. there was a lot of trash in the fuel system from sitting for 2 years.
I had to replace my IAT sensor twice. The first time it was reading high, 180*. No SES or any problems driving it. The 2nd time was the new sensor, it was reading way low, below freezing. The SES would come on at random times, and fuel mileage sucked!
Old Dec 20, 2005 | 07:56 PM
Dale's Avatar
Engine: 350 S-TPI
karr, this all started when I bought a new tank of gas. I finally got a chance to crack the system open, and the filter was dirty. I assume it was from that tank of gas.
bru. Thanks for info. Injectors will go in asap.
Just tested IAT/MAT. That was a fun test to play with
Old Dec 20, 2005 | 09:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did you happen to fill up durring/right after the gas station tanks were being filled?
Old Dec 21, 2005 | 05:39 AM
Dale's Avatar
Engine: 350 S-TPI
Wasnt any tankers around that night. Dont know when they fill up.
And yes I know what your getting at, and have thought/wondered that myself.
Old Dec 21, 2005 | 12:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hmmmm....I wonder what kind of gas they got there! But I'm sure it'll all work out soon
Old Dec 21, 2005 | 01:24 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
you might try dumping ALL the old gas out and refilling the tank completly with fresh gas,and add some HEET or other water remover with it.
but if it sat,then the injectors are probably clogged as well.
Old Dec 21, 2005 | 03:17 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
"IAT" that the sensor on the air filter can? I had that zip tied to the support of the nose, maybe that's why my gas milage blows.
Old Dec 21, 2005 | 03:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
that could be part of it.... especially if, for some reason or another, your intake air would be radically different from the temperature the sensor was reading...
Old Dec 21, 2005 | 03:51 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hmmm....regarding the dirtry fuel. I read in the carb section that one gas station accidentally mixed diesel with the regular gasoline. Perhaps you got some diesel in there from that gas station?
Old Dec 21, 2005 | 07:40 PM
Dale's Avatar
Engine: 350 S-TPI
Already drove all the old gas out.
Its to be 60deg here saturday, so thats prime weather for cracking a fuel system open. New injector time it is
Old Dec 21, 2005 | 08:18 PM
Engine: 5.7 / 7.4
Dale, I think you're gonna go thru more injector swaps than I've done engine swaps
Old Dec 21, 2005 | 09:48 PM
wildOne87's Avatar
Car: 87 camaro, '02 cbr600f4i, 70 mustang
Engine: 2.8/600c.c/ 351C
Transmission: Manual/Manual/Slap stick
dale, check the numbers on the injectors, and make sure they are all the same.....
remeber the injectors you gave me a while ago, well only 2 of them were the same, the rest were odd sized injectors but prety close... i got new ones, and now the engine runs well... just a thought to get you going again..... also, if i remember you were running 17#ers still, you are definately running rich with them in there, try spraying a mist of water in the intake to clean the carbon out of the engine it takes almost a liter of water to do the trick... i swear it works and it won't hurt anything... i have done it with every vehicle that i own, and i have never had a problem with it, car runs better after i blow all the carbon out than what they did when i got them.
Shaun
Old Dec 22, 2005 | 08:41 AM
Dale's Avatar
Engine: 350 S-TPI
I'm just an injector ***** I dont understand the ecm tuning, so I try to tune with injectors.
87, YGPM
Ghettobird52
Jul 5, 2024 11:18 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
