im getting rid of all my ****, im putting in new pipes and new mufflers but i dont want to run a Y muffler to dual exhaust, i want to run each individual muffler with pipes from Headers, any opinions in what i have to make sure i do before putting in the headers?
69charger383
close
- Join DateAug 2005
- LocationConnecticut
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car2005 Lincoln LS, 83' Z28
- Engine242 DOHC and an empty engine bay.
- Transmission5R55S, T5 soon to be auto
- Axle/Gears3.58s and soon to be 4.10s
- Liked:0 Times in 0 Posts
If your gonna use the Pace setters I dont think your idea is gonna work. The design they used is weird for clearance and Im pretty sure youll have more than a 90* bend right after the drivers side header. Not positive tho.
hmm...im not sure if i should get shorty headers or longer ones, which do you guys recommend ?
69charger383
close
- Join DateAug 2005
Id go for long tubes.
Really I wouldn't go for "true dual" system in a 6 cyl. You need some of that back pressure. If all you want is a better flowing system, just get larger pipes. But its all about the way you want it.
Im wondering if you'd have a problem with placement of true dual pipes, I dont recall there being a good place for that second one unless it was hanging below everything, and from looking at my car Im pretty sure 2 pipes wouldnt fit side by side anywhere. Not to mention you'd have to get hangers for it too.
a set of long tubes followed by 2 LONG glass-packs the turn downs or take it out the sides
Supermann
close
- Join DateJun 2004
- LocationDelaware
- Car'86 Camaro, '85 Z28, '92 Firebird
- EngineLB8 2.8, LG4 5.0, LO3 5.0
- TransmissionTH-700R4, T-5, TH-700R4
- Axle/Gears3.42s, 3.23s, 2.73s
man, I am pretty sure other people have tried this and its not a good idea at all. Sounds like total r!ce above idle cause you only have 3 cyl going to each muffler. if you do decide to go through with it, make sure you have some type of crossover or h-pipe or something (balances out the sound and actually really helps performance)
