2.8 mpfi question
Old Jan 25, 2006 | 05:00 PM
tippmann243's Avatar
Car: 89 s10 blazer
Engine: build 4.3
Transmission: t56 6 speed
Axle/Gears: 4.56's
2.8 mpfi question
i was wondering how the fuel injectors are fired on a 2.8 mpfi motor
batch, bank, or sequential, im assuming batch but just thought id ask
thanks
-mark
Old Jan 25, 2006 | 08:35 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i'm about 99% sure its batch.
Old Jan 25, 2006 | 08:53 PM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
yeah thats what i figured, i rememberd after i posted that the car needs acam sensor to be sequential
and i dont see why they would do bank
thanks for the help, this helps my project
Old Jan 25, 2006 | 09:03 PM
Car: 91 Camaro
no problem. mind if i ask about this project??
Old Jan 26, 2006 | 09:55 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
They're bank fire, though they're effectively batch fire depending on rpm/load. (I'm not sure how the stock ECUs handle sync/async fueling... been spending too much time staring at $58)
Old Jan 26, 2006 | 10:21 AM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
mpfi 4.3 v6
i was planning on running a sy/ty ecu but they are to rare/expensive and if i mess it up im screwed, where as a 2.8 mpfi ecu could be a freebie from the junkyard
Old Jan 26, 2006 | 03:57 PM
Car: 91 Camaro
Originally posted by tippmann243
mpfi 4.3 v6
you can run a '730 ecu with the sy/ty code (ID is $58). a little repinning is involved from the stock harness off of a 3.1 but its do-able.
Old Jan 28, 2006 | 08:10 PM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
its a little bit harder then that, but thanks for the help
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
86Base
Aug 8, 2015 01:34 PM
