help needed
Old Jan 26, 2006 | 12:53 PM
dunewolf's Avatar
Car: 83 firebird
Engine: in pieces
Transmission: to many high rev shifts
Axle/Gears: cant find them
help needed
aight i blew my 2.8 yesterday (83 firebird) and i got a 2.8 from an 86 camaro tbi i think with no intake just bare block just rebuilt. will the carb and crap from my 83 fit on it.? if not does any one have any idea. what all will fit and what wont. and will it fit in my 83?
Old Jan 26, 2006 | 01:22 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the blocks should be identical. just put All of your stuff off of your old engine on it and it should work.
Old Jan 26, 2006 | 02:03 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
I think you will also need to get an in-line electric fuel pump for a carb. The '86 2.8 is fuel injected but has something like 30 more HP than your '83. Enjoy the difference.
Old Jan 26, 2006 | 02:18 PM
dunewolf's Avatar
Car: 83 firebird
Engine: in pieces
k thanks
Old Jan 26, 2006 | 02:58 PM
xplane's Avatar
Engine: 2.8 MFI
But he said he wasnt getting the Intake so he dont need to do anymore than put his carb setup on this block to be back to running. plus he would ned the ECM and the wiring harness for the engine aswell to get it to work and if your gonna go that far you might as well just get a 3.4 from a 4thgen and put it in there.
Old Jan 26, 2006 | 03:04 PM
dunewolf's Avatar
Car: 83 firebird
Engine: in pieces
sorry i am no w confused. so i need to put my carb and manifold on and also the ecu crap?
Old Jan 26, 2006 | 03:18 PM
xplane's Avatar
Engine: 2.8 MFI
No you sid in your first post it was just a bare block right? then all you do is take EVERYTHING missing from the new block off of your old engine and put it on the new block and put it back in the car. now if you wanted to get that Extra 30 hp you would have to get everthing for a MPFI car such as the intake, ECU, fuelrail, injectors, and anything else the system needs. the two will not mix and match. i was refering to using the fuel injected intake versus your carb system in the prior post and that to get the MPFI to work oun your car would be the same nomber of changes as installing a much more powerfull 3.4 with its ECU and such. k?
Old Jan 26, 2006 | 03:20 PM
dunewolf's Avatar
Car: 83 firebird
Engine: in pieces
ohh ok ic i c thanks
Old Jan 26, 2006 | 03:22 PM
xplane's Avatar
Engine: 2.8 MFI
your welcome.
Old Jan 26, 2006 | 04:27 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
I don't think the '86 block has provisions for a mechanical fuel pump.
Old Jan 26, 2006 | 04:50 PM
dunewolf's Avatar
Car: 83 firebird
Engine: in pieces
will any inline fuel pump work or is there a specific one i should use
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
