View Poll Results: What car should I buy
1992 RS V6
0%
1987 Z-28 V8
100.00%
Voters: 10. You may not vote on this poll
I need your guidance. Please help!
Old Jan 29, 2006 | 04:18 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
As some of you may remember I had no chioce but to junk my Camaro Last October. I'm finaly in a position to get another one. My options are 1992 RS 3.1 V6 Auto w/ T-Tops 114k miles that needs a fender/door/hood/bumpercover/and exhaust for $1000 (I can probably talk him down some). My other option is a 1987 Z-28 V8 LG4 5-speed 68k miles and the engine was rebuilt 14k ago, bored 30 over. Needs Carb rebuilt or replaced, back breaks and weather stripping for the doors and the guy said $750.
My problem is I really want T-Tops, but I really want a V8/5-Speed even if it is the LG4. Tell me what you think
I figured I could post this here on the V6 board because if I did anywhere else I would get all the V6 Haters saying "Get the V8, V6's suck" Blah Blah Blah. I've owned the V6 Camaro and I liked it. So what it wasn't that fast.
Old Jan 29, 2006 | 05:39 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
i would go with the v8/t5 . . . thats a killer combo, and its easy to mod up an lg4 to be fast . . . if its carb then your already set pretty much . . . hell, you can just drop a 383 in there no problem with a new carb and you'd be set.
i do like the 91-92 camaro's a lot, but since the v6 isnt a manual and needs all that body work, go for the z28.
Old Jan 29, 2006 | 09:13 PM
Anyone else?!?!?!?
Old Jan 29, 2006 | 09:18 PM
Naed's Avatar
I personally do not like t-top cars for the simple reason that they can not handle as well being a weaker unibody structure with more flex than a hardtop.
If the t-top car is important to you though then my opinion would be to wait for more future choices and scrap these two.
Old Feb 1, 2006 | 08:43 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
either wait like Naed said or go for the v8 one. I don't say that often but it sounds like its in better shape and its cheaper and you can always swap to the newer ground effects if you like them more.
Old Feb 1, 2006 | 09:40 PM
daves12secV6's Avatar
go for the 87 for one 1g for a v6 car with that much needed to be replaced is not worth it id offer the guy 250$ for the rs, and + with the v8 car if u ever want to upgrade the engine with a 350 it already has the v8 suspension/fuel system/transmission etc
Old Feb 1, 2006 | 11:33 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
can you cut and weld?
i bought the roof off of a towncar that had a moonroof from a wrecker for 150$
there are a few guys on here that have done the swap if you search.
even if you dont id still get the z28. im sure the posi 5 speed and v8 will make you forget you wanted ttops for awhile
Old Feb 2, 2006 | 02:42 AM
Thanks guys. I am going to check the 87 Z-28 out next week. I am hoping the guy isn't BSing me any. I really want everything to work out. Because I could have it before the end of Feb. I already have a Holly Carb coming from a guy at work for free (needs a rebuld) if I get it. Wish me luck. And Performance parts a cheap for it.
Old Feb 2, 2006 | 02:50 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
yeah i liked ttops too. now i have a hard top and i will never look back.get the z28
Old Feb 2, 2006 | 10:20 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
Im a fan of t tops but Id go for the Z. sounds like a good deal, carbs arent horribly hard to rebuild, but bodywork is esp if you're like me and super **** about getting everything perfect, not that it makes it hard or anything but well...trust me I will take my sweet *** time working on one piece making sure its right.
Old Feb 3, 2006 | 09:06 AM
stocker85's Avatar
the z28,,,,,,,,,,,,,,,,,,,unless gas mileage is a big problem for you,,,,or let the guy with the rs sit on it for a while,,,,,then go back and if he still has it try n get it dirt cheap,,,,one d.d. one for burnouts
Old Feb 15, 2006 | 10:04 PM
Thanks for your "guidence". I went to see the Z-28 yesterday and It turned out that the reason it was stalling was that a spark plug wire melted to the manifold and it was loosing spark.. Any way I am going to purchase the Z-28. I just gotta get it down here. Its like 2 hrs away from my house
Old Feb 15, 2006 | 10:28 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
welcome to the world of the mighty 305!!!!
with bolt ons, it might be as fast a 3800 Series II
I'm hoping mine will jsut run (at least w/e-check gone i wont have to worry about 30 tags this time)
cuzimanoob
Sep 25, 2020 02:29 PM
jimw67
Dec 27, 2015 03:42 PM
fivestar
Jan 19, 2015 10:03 PM
Jcase350
Feb 28, 2014 01:44 AM
wruiz
Dec 11, 2013 04:49 PM
