multipule questions.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
One of these didnt get answered in gen tech, maybe someone here will answer.
1. When data logging on the ecm, where does it get its timing and rpm readings from? ICM, Coil, elsewhere? I know the tach comes off the white wire of the coil.
2. When the ecm goes into "ses" mode, why does it automatically dump in more fuel causing even richer conditions?
3. Since its known I had debris in my gas. Co worker thinks that will driving the car before finding this, but post changing my o2, I have contaminated my new o2 sensor. Agree, Disagree?
4. Driving my car while its better, it still has problems (randomly). It tends to be getting better every mile I drive it? Why? Where should I be looking, or anything I could do to speed up the "healing".
5. Who was the board member that said they might have some 17lb injectors forsale? Are they a matching set? Cause I have 11 but none to make a matching set :sigh:
6. Anyone know of any good material I could put around the base/seal of my egr valve to prevent it from blowing the gasket it.... more/again? So I can put it back on and quit getting a code32.
That is all for now, maybe more later.
dale try some .090 aluminum for the gasket on ur egr valve or thin copper material, i use aluminum header gaskets and collecter gaskets and have never had them blow out, so im sure they would work fine for ur egr valve
Engine: 350 S-TPI
its not where the egr mounts to the headers. Its an internal gasket in the egr. I dont know how to(or want to) take the egr apart to replace that gasket.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
1. The ECM gets it's RPM signal from the ICM which gets the original signal from the pickup coil.
2.When the SES light comes on it goes into "Limp" mode, causing a rich condition full time because running too rich is ALWAYS better than running too lean. It's to avoid possible engine damage when there is something wrong that might change the fuel delivery.
3. Very possible.
4.Did you have the injectors cleaned and the screens replaced? How about replacing the FPR. Some debris might have gotton stuck in it causing problems.
5. Wasn't me...lol
6. Don't you have an electronic EGR? There's no seals in them, they're just solenoids that plug passages. Now, if you do happen to have a vacuum controlled one, if you keep blowing out the rubber/base gasket, then you have WAY too much pressure in the system. I would check that out first.
3. Very possible.
5. Wasn't me...lol
Engine: 350 S-TPI
2.8boy.
1. thats what I was thinking.
2. Got it, ugh.
3. thanks
4. nope, never had a set cleaned. I've swapped the FPR as well.
5. got it.
6. yes, its digital EGR. I'll snap a pic this weekend when I get the loaner camera. Trust me, its got internal gaskets that blow. This is the 3rd one thats blown in the same spot. I got tired of paying 200 for the things to last 3-6 months.
2. Got it, ugh.
3. thanks
5. got it.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Check the backpressure in the exhaust system. You should have <2 psi in there, which shouldn't be enough to cause the seals to blow out.
Engine: 350 S-TPI
pic as promised. Had to test this loaner camera out before tommorow anyway.
Edit, and I dont have to much pressure in the exhaust. Headers, offroad y-pipe, and catback.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Might have a warped EGR flange. I know my Volvo has a warped exhaust manifold so it just blows out gaskets like they wern't even installed. I just gave up...lol
Just trying out some thoughts here. Gotta cover all the bases.
Engine: 350 S-TPI
Originally posted by 2_point8_boy
I would check anyway. I don't know the last time you had the cat off and looked inside,
offroad y-pipe
Warpped flange is where it mounts to is possible, thanks.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
double, tripple gasket with some indian head gasket sealer.
brown bottle. Some nasty sticky stuff that will seal even the nastiest warp leak.
Engine: 350 S-TPI
Got a gm egr at the junk yard today
Found R-bobs 280-150-901 injectors
Later today, going to get a new o2 sensor and egr gasket.
Install all that with new fuel filter tommorow and see how she runs.
Engine: 350 S-TPI
YES
New fuel filter in, no issue with old one.
New o2 in. "old" looked nasty, but ive seen worse reading properly.
Checked my plugs since "plugs never lie". I'm getting a random miss fire on #1. So I gotta decide what route to take to find that problem.
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
