Can the stock Throttle Body be bored out?
Old Feb 11, 2006 | 09:15 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
if even just a little bit? Can it be bored out?
Old Feb 11, 2006 | 09:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I belive someone on here tryed, and found you could only go 1-2 MM before the walls became to thin. That bit is not worth the effort.
Old Feb 11, 2006 | 09:22 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Whats stock? 48 Mm right?
Old Feb 11, 2006 | 11:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I thought they got more then that out of them.
Id check some fiero sites n double check. The TB is different on some of the cars. I know the 90s 3.1 TB is nothing like my 86 2.8 TB.... TPS and IAC are mucho different.
I was thought there for a while throug hthe mfiero sites there was a place or two boring them out but do believe Dale is right but only half way. Not all could be modded. But who knows, been a member so long n read so many post, it all runs together.
Old Feb 11, 2006 | 11:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Though as I jog my memory I think 52mm was the max. And maybe on a bone stocker it wouldn't help [course who just slaps a bigger TB on a bone stocker n expects anything?] but there has to be a point where them extra MMs do help.
Old Feb 12, 2006 | 12:12 AM
Thunderfest's Avatar
52mm is stock on 3rdgen 60V6's. The Fiero TB 's are offered in a 3mm over bore which are a different design that ours factory TB's and I have seen info sugggesting possibly that they are only 48mm stock (I can't confirm this though!)
Old Feb 14, 2006 | 08:01 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I think AM91Camaro_RS bored the stock TB and just ended up building a custom one because the stock didn't yeild any results really.
Old Feb 15, 2006 | 10:33 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I did start to bore a stock one, never finished it. But, the mentioned 2mm looks like it'd be about the limit and even going that far might require some other modifications.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
