Just A thought about a 2.8 to 3.1-3.4
Old Feb 12, 2006 | 02:40 PM
madathlon's Avatar
Car: 1988 Camaro, 1960 F-100
Engine: 2.8L V6, 223 inline 6
Transmission: TH-700R4, T98
Axle/Gears: 3.42/3.11 Posi Lock
OK I have lived in cali for a few years now and 1 thing I have learned is in engine modding around here is if it cant be seen than its will most likly pass smog with out much problem.. IE: like stroking a 350 to a 383.. smags jsut fine and no quiesting asked.. So here my thought.. could I use a 3.1 or 3.4 block and innards and the 2.8 intake and assory.. IE alt, steering, A/C brackets and units.. And how about the ECM and wiring?
Old Feb 12, 2006 | 02:52 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
yes you can. you just use the 3.4 Block, waterpump, and the 3.4 injectors in the 2.8 fuel rail. the injectors are the same only the 3.4 ones deliver more fuel to makeup for the larger displacement.
Old Feb 12, 2006 | 02:57 PM
madathlon's Avatar
Cool.. So I can make a sleeper 3.4 with 2.8 marking and parts..
Old Feb 12, 2006 | 03:03 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
read up on Karls' (KED85) article in the tech article section. He did this swap on his 85 Bird & Blazer.
Old Feb 12, 2006 | 03:14 PM
madathlon's Avatar
I looked at that.. not any real info.. I like to know if my ECM needs to be changed and if the harness needs changing also.. or are we talking a direct replacment here? Just swap block and parts? or will I need diffrent exh, oilpan, or is this all justa bolt on job.. Smog here can really tie me up if thay find a excues to not pass it here.. And I have to also pass a light, brake check.. ( Have no clue what there looking for there.. ) Never had to do that one before..
Old Feb 12, 2006 | 03:19 PM
xplane's Avatar
Engine: 2.8 MFI
the 3.4 is bolt for bolt Identical to a 2.8L block exept for 2 differences i know of, the waterpump circulates in the opposite direction which is no big deal cause you just use the 3.4 pump, and it dont have a boss for a mechanical clutch on the rear of the block, no big deal cause you have a Auto. the ECU and everything else will work on the 3.4 you only need to change the injectors to the higher flow 3.4 injectors to compensate for the extra CID.
Old Feb 12, 2006 | 03:24 PM
madathlon's Avatar
Thats great news.. Im going to keep my eye out for the next pick and pull sale on engine and grab up one..
Old Feb 12, 2006 | 03:43 PM
Thunderfest's Avatar
The 3.4 RWD block has a distictive "F" casting on the side of it as well as cross hatch reinforcement ribbing as seen here. The FWD 3.4 and the rwd 2.8 and 3.1's do not have these markings and reinforcment.
Old Feb 12, 2006 | 03:45 PM
madathlon's Avatar
ok? So do not get that block?
Old Feb 12, 2006 | 03:48 PM
DO look for that block casting on engines in a salvage yard. Its the one you DO want.
GM has stopped making these motors as crate replacement engines last year when the 4th gen 3.4 became over 10 years old. You can only find them used now.
Old Feb 12, 2006 | 03:50 PM
madathlon's Avatar
no problem.. I was planning on pullng one for a S yard anyway..
Old Feb 12, 2006 | 03:58 PM
So you know, I am actually an old member around here with 1000's of post, just an new name (Long story)
Anyways, I too live in So Calif (City of Orange)and am going to be putting my 3.4 into my wifescar within about the next year- Its a proven smog inspection passing stealth swap. I need to finish major house projects first then I will finish my motor project. I do know these cars like the back of my hand. Any info you need on suspensions etc, just ask and I can help point you as to whats the best bang for the buck. Most of everything I have done to our 3rd gen is custom 1 of a kind stuff though. Here's a link to it.
https://www.thirdgen.org/techbb2/att...postid=2162232
http://www.cardomain.com/ride/518752/1
Old Feb 12, 2006 | 04:04 PM
madathlon's Avatar
Cool looking.. So U know about dealing with cali smog.. I had a 86 Ford Ranger that wouldnt pass smog becouse a code keeped popping up for a tranny problem.. that real problem it was a code for a auto and it was a 5 speed..
Old Feb 12, 2006 | 04:27 PM
xplane's Avatar
Engine: 2.8 MFI
Hmm is this where a Fan switch goes on a 2.8?
Old Feb 12, 2006 | 04:30 PM
madathlon's Avatar
Just a thought tho.. what cars have the 3.4 block that I will be looking for?
Old Feb 12, 2006 | 04:37 PM
xplane's Avatar
Engine: 2.8 MFI
93+ Firebirds and camaros that came with V6s. some where in the middle of the 4th gen run they changed to 3.8s but i dont know when they switched.
Old Feb 12, 2006 | 04:42 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
93 - 95 I beleive. Camero and firebirds.
Old Feb 12, 2006 | 04:50 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I created a thread with all your answers, and step by step directions.
https://www.thirdgen.org/techbb2/sho...hreadid=339280
Old Feb 12, 2006 | 05:06 PM
madathlon's Avatar
thats great info Dale.. thanks for the tech.. Now I have a full plan ..
Old Feb 13, 2006 | 01:50 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
in this picture, where is the sensor that has to be moved? I think it was the crank position sensor or something?
Old Feb 13, 2006 | 02:22 AM
iroc-z's's Avatar
Car: 88 camaro rs
Transmission: auto
how much more hp will the 3.4 block give you over the 2.8 block?
Old Feb 13, 2006 | 02:30 AM
1989karr's Avatar
Engine: 3.4 / 5.0
ooo I got this one!
2.8 = 135 hp
3.4 = 160 hp
1989karr's Avatar
Engine: 3.4 / 5.0
ooo I got this one!
2.8 = 135 hp
3.4 = 160 hp
Old Feb 13, 2006 | 05:40 AM
Dale's Avatar
Engine: 350 S-TPI
Read the thread I linked too.
Old Feb 13, 2006 | 09:15 PM
iroc-z's's Avatar
Car: 88 camaro rs
Transmission: auto
ooo I got this one!
2.8 = 135 hp
3.4 = 160 hp
ya but will the 2.8 intake make a loss of any hp?
Old Feb 13, 2006 | 09:26 PM
xplane's Avatar
Engine: 2.8 MFI
the 3.4intake plenum is the same on the bottom they just changed it to clear the 4th gen hood. i have seen one and it did not look like it had any more flow capacity.
Old Feb 13, 2006 | 11:13 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Just wanted to correct this info, the FWD 3.4 AKA 3400 does indeed have the reinforment, also the block around the cylinders is buldged, to provide a higher capacity of coolant, around the cylinders.
Old Feb 13, 2006 | 11:17 PM
madathlon's Avatar
So this would better handle the higher heat around here than if I get this right.. More coolent means better cooling compacty..
Old Feb 14, 2006 | 12:15 AM
xplane's Avatar
Engine: 2.8 MFI
only of you want to F with trying to fit a FWD block with very different mounts into a RWD car. it can be done cause i think some one on here on TGO was talking about it. I think it was doward?
Old Feb 14, 2006 | 08:40 AM
The_Raven's Avatar
This si true, the FWD block is not a blot in to the RWD chassis.
I will most likely be starting with a FWD block for my Frankenbeast build, since I'll hgave to fit the chassis to it anyway. Still looking for a good chassis.
Old May 8, 2006 | 02:04 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
on that pic u posted the one part that is circled with black is that the sensor everyone says gets in the way and is a bitch cause i just pulled out a monkey wrench took it off and stuck a hex plug that is used by plumbers.
Old May 8, 2006 | 09:47 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
and 160 ft lbs - 200ft lbs!!!, i gave up on removing the damn plug from the head, i drilled and tapped a hole 11/16" drill bit and 3/8" pipe tread tap, but when i swapped heads i smashed the fan switch that i had moved and it was in a tight spot..so i ended up putting a fan switch back in its original spot since the hole was open..it might be cheaper to ask for a 3.4 short block and have your 2.8 heads rebuilt or get new ones and put them on, because based on what ive read, it takes WAYY to long to remove that plug...and you could have swapped in new heads by then and not ever have to worry about that valvetrain breaking down. i wish i did that first, cuase i cooked valves on both heads and replaced them both anyway
Old May 9, 2006 | 03:55 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
oh u guys are talking abou that sensor on the corner of the one head? cause i'm just gunna leave it in if worked b4 with it in it will work again.
Old May 9, 2006 | 04:40 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I say send the heads to a machine shop and have them deal with the removal of that plug
Old May 9, 2006 | 05:23 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
does it end up getting in the way?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86maro_252
Oct 10, 2015 06:52 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
IROCZ1989
Sep 4, 2015 11:54 AM
