v6 tranny
Old Mar 12, 2006 | 04:46 PM
adam86's Avatar
Car: 1989 GTA
Transmission: Stock 700r4
Axle/Gears: 3.08 POSI
v6 tranny
hey i bought a firebird and it needs a new transmission and mayebe a new differential.
how hard is it to take the tranny out and put it back in... is there anything i am probably going to have alot of trouble with?
and another question that has nothing to do with the tranny..
the 2.8 engine runs great beside the transmission.. do you think this car is capable of doing good donuts on a dry or slightly wet surface?
Old Mar 12, 2006 | 04:49 PM
daves12secV6's Avatar
used trans from junkyards run anywere from 175-300
it takes me an hour to swap out a trans in a v6/v8 camaro,as long as u have all the right tools its not very hard to do
u could prlly do donuts on wet ground though v6 cars dont have posi's so its a lil harder to do
Old Mar 12, 2006 | 04:52 PM
adam86's Avatar
Car: 1989 GTA
im planning on getting my trans rebuilt for $550 at some shop...
and for the posi thing im going to getting a rear end from a 89 firbird with tpi.. im pretty sure it has posi?
Old Mar 12, 2006 | 05:24 PM
make sure before u buy it, not all v8 cars came with posi rears, also find out the gear ratio in that rear if it is diff from what u have now u will need to get the correct spedo gear for the trans. or ur spedo wont read right
Old Mar 12, 2006 | 07:06 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
plus if you end up with the 2.73 posi you wont have enough torque getting to the ground to even spin both the tires. 3.42 or 3.27 will be hard enough with the posi on a stock engine.
Old Mar 13, 2006 | 12:29 PM
adam86's Avatar
Car: 1989 GTA
damn so these v6 engines are really that weak that they cant spin both tires with posi? my friends 94 v6 mustang can do dounuts all day and his engine is gone to ****? whats the deal
Old Mar 13, 2006 | 01:11 PM
Naft's Avatar
im just guessing, i dont think anyone ehre has bothered to put posi on a stock v6 engine. i know with my auto tranny i couldnt spin the tires at all, although my back tires were pretty huge, which doesnt help. its easier to spin the tires when there is a side load too though(like doing a donut), so who knows, it could happen. just put some 205s or something on there and keep the air pressure up high to make the contact patch smaller. there's a big traction difference between 46 psi 205s and 34 psi 255s.
Old Mar 14, 2006 | 05:56 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
You'll need to tip the motor and tranny back a bit when your removing and when your reinstalling, take OFF the distributor cap, some recommend you take out the whole distributor. Otherwise you'll break it against the firewall.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
