headers and torque converter
Old Apr 23, 2006 | 12:24 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
does pf&e headers have 1 3/4 primaries reason i would like to kno is because i am gonna do the 3400 top end swap and i hear you can only do the swap if you have headers that have 1 3/4 primaries. Also i want the crane 260h cam w/ 3.42 gears so what stall torque converter should i get and who makes them for are cars?
Old Apr 24, 2006 | 02:25 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
as far as i know it doesnt make a diffrence, they all bolt up the same...im using pf an e headers on my 3400 swap and i bought them for my 3.1 a few years ago
Old Apr 24, 2006 | 05:10 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
headers
what size are the primaries?
Old Apr 24, 2006 | 06:10 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I use 1.5" primaries on the 3400 top end, then again I am using a turbo each time it seems.
On a mildly built or stock top end swap 660, you don't need anything more than 1.5" primaries at less than 30" long.
Old Apr 24, 2006 | 06:14 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
thanks sixshooter
thanks that means i can run pacesetter headers then i was waiting for somebody with the swap to respond so i kno to buy headers or not. Anybody got any torque converter info for me?
Old Apr 25, 2006 | 11:10 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
I have a set of pf&e headers I havent put on yet. The primaries on mine are 1 1/2".
Old Apr 28, 2006 | 10:04 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
talk to some different tq converter companies, you have to tell them that you have the 60degree v6. the converters are smaller and built differently than v8 stuff. but, they are available!
Old Apr 28, 2006 | 10:14 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
torque converter
what companies should i call?
Old Apr 29, 2006 | 08:16 AM
Uncle Creepy's Avatar
Car: 91 Pontiac Firebird
Engine: V6
Transmission: TH700R4
Torque converter
Haven't seen many offerings around for torque converters for the V6 ...
Just this one from Precision Industries, and information is very vague on their website ...
Precision Industries - Vigilante Torque Converters
You gotta love that color ... good thing a torque converter isn't in plain sight ...
Old Apr 29, 2006 | 09:06 AM
Car: 91 Camaro
i got mine off of ebay...the company's name is roadrunner converters. they are out of arizona, i think.
Old Apr 29, 2006 | 10:44 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
vigilante
I wonder if they sell those torque converters at any stores?
Old Apr 29, 2006 | 11:22 AM
Engine: V6
Vigilante
I've only seen them for sale on the Thunderracing website.
They don't even mention the V6 version, but i guess if you contact them they may be able to help you out ...
Thunder Racing - Torque Converters for your 1982-1992 F-Body
Old Apr 30, 2006 | 09:26 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what size stall
which size stall should i get if i have a 3.42 gears and a small cam with about .454 lift?
Old Apr 30, 2006 | 10:41 PM
daves12secV6's Avatar
tcui makes converters for the 60*v6 trans, i just spoke with somone from over there about getting a 3000+ stall verter for the rs for the turbo motor,B&m also makes converters for the 60* v6 trans.
edit btw stay under 2500 stall with the na motor,unless ur really bringing the comp ratio up,and ur really using a cam that makes its power up high
Old May 1, 2006 | 05:50 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
do you mean tci? also that b&m torque converter wont work for a 60 degree v6 and i havent seen a b&m that does fit 60 degree v6 all v8 or 90 degree v6 converters.
Old May 2, 2006 | 06:43 AM
yes "tci" dam typos lol just goto there website and use the recomendation slip and thy will tell u the best converter for ur setup,or u can give them a call
Old May 2, 2006 | 11:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yikes! That must look funky under a blacklight!
Yeah I also thought TCI made one too. If you ask on the trans board, someone there might know. There used to be a guy on there named transfixleo, he was a tranny tech who rebuilt his v6's tranny with all the hi-po stuff AND a performance torque convertor. Or just do a search on his username (transfixleo) and you might find a message or two about it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
