Quick question
Old May 2, 2006 | 12:17 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Quick question
I did a search but i dont think i search for the right thing...
That sensor by the oil filter is called the Oil pressure sender right???
Old May 2, 2006 | 11:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm trying to remember the 82-84's... but yes, I think there's just a single one-wire sensor in that spot, right? And it goes into the oil filter mount? If so, that's the pressure sender.
Should be easy to check; I believe if you unhook it and then start the car, your oil light comes on (because it sees 0 volts).
85-92's have different setups then your car...
Old May 2, 2006 | 12:27 PM
Drew's Avatar
If its running a light, rather than a gauge, it'd be a switch, not a sensor.
Old May 2, 2006 | 01:59 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
the berly has the guadge so its a sensor right? ( so i should ask for an oil pressure sensor?)
Old May 2, 2006 | 02:36 PM
Drew's Avatar
or sending unit... Since its a Berlinetta you might run into an issue finding the right part since it might be different for a digital dash. But then since its an 83 your car shouldn't have the digital dash so you need the same sending unit as any Camaro with full instrumentation. Confused yet?
Old May 2, 2006 | 02:39 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Ive been confused since day one with this car im gonna go run out and take a quick pic of what i'm talking about on the car...
Old May 2, 2006 | 02:49 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
here is what im talking about...
Old May 2, 2006 | 08:05 PM
Drew's Avatar
Yeah that's your oil pressure sending unit.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
