engine mount help 4 84' 2.8
Old May 12, 2006 | 10:14 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
how difficult is it to add a new mount on the passenger side on an 1984 2.8l?
Old May 13, 2006 | 06:30 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
by adding a new mount, i assume you mean replace it right? they are not fun at all. the mounts are held onto the frame w/ bolts that have nuts on the back side. those nuts are very hard to access. ive been trying to find enough time to replace mine w/ some polyurethane ones i bought. and its a 2 person job, one under the hood, one under the car.
Old May 13, 2006 | 10:19 AM
Car: 84' Trans Am
thanx 4 the heads up, ill probly have it taken in then.
Old May 15, 2006 | 10:43 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
if your 84 engine bay is anything like mine, its really not that hard to get to the bolts, i was able to do the mounts myself w/o any help, just put the car up on some jack stands (one on each side in the front) and use a ratchet w and extion on one end and a breaker bar on the other, true its eaiser with another person, but it is a one person job that should take no longer then an hour or two depending on how many people ask why the hell you are working on a v6 camaro
Old May 15, 2006 | 10:49 PM
Car: 84' Trans Am
lol, thanx 4 the info, i really need too get it fix. every time i give it the gas it makes the worse clunk. its the passenger side so its less crowed on that side.
Old Jun 6, 2006 | 04:42 PM
Car: 84' Trans Am
sorry guys i know its been awhile and didnt want to post a new thread about this but heres a pic of where its at, does it look hard to do.
Old Jun 6, 2006 | 08:09 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
That Metal piece that is connected to the frame is part of the motor mount, Its easyer to access the mount from under the car, it really isnt that hard and a one person job if you have the right tools (a ratchet,a few extentions, and breaker bar, with one haveing a deep socket, so that you can get to the nut.
sorry for the poor spelling, Cant seem to spell today...
Old Jun 7, 2006 | 12:13 AM
Car: 84' Trans Am
thanx i think ill try it this weekend, btw ur spelling isnt that bad.
Old Jun 7, 2006 | 12:42 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
looks similar to my 91 mount, location wise.
it is a pain in the *** job,
if I remember correctly there's like
bolt and nut that will turn together so u'll have to like lock one up while u turn the other one..
not sure on ur 84, but for me I just gave up after 2hours
caz all I could took off was the main bolt,
which's the easiest one.
P.S. shop charged me for 3hour labor for both.. but took 5hours to finish.. go figure!
Old Jun 11, 2006 | 08:13 PM
Car: 84' Trans Am
Sorry guys but to day i parked it on ramps and went under and found out its the tranny mount, how hard of a job is this, transmission is a 700r4.
Old Jun 13, 2006 | 02:03 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
this very same problem happend to me.. turned out to be driver side cross member,. bolts were striped out so the cross was hanging on that side.,i had to re thread the holes to one size bigger ,.i almost went with heila coils,.but the rethreading worked well,.,.also i found that this cause bolts to rip out from. my motor mount up front,. but the cross fix worked well for 2 years now,..,only thing that can be hard about rethreading the holes is youll need a good amount of arm straingth to tap the hole,..,you need to remove the whole thing [cross] so you will be holding the trans up with the jack,. unless the bolts fit back thru the threads.,oh yea this is also a good time to check your trans busshing in the middle as well
Old Jun 13, 2006 | 09:28 AM
Car: 84' Trans Am
sorry about the mistake, instead of trannny bolts i ment tranny mount. sorry for the mistake.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
