knocking engine
Old May 15, 2006 | 02:22 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
knocking engine
how long will a engine last with it knocking? (the engine is a 2.8l) i figure ill drive it till it dies but wanted to know how long it will last?
Old May 15, 2006 | 02:46 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
you will be driving it for a long time if you take care of it and your engine is fine i still dont think thats a knock you are hearing and you have very low miles on that car
Old May 15, 2006 | 02:49 PM
Car: 84' Trans Am
just curious how long they last for instance how many miles u can get outta them? anyone know?
Old May 15, 2006 | 02:56 PM
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
my 85 trans am had a lg4 305, bought it with a slight knock with 82k, sold it with 112k with the same slight knock, lucas oil additive seemed to have taken good care of it, expensive but useful...ive seen 2.8s running 125-200k without rebuilds, mines currently got 72k, slight valve or maybe lifter tick...
Old May 15, 2006 | 02:59 PM
Car: 84' Trans Am
ill try some of that lucas oil, ive seen it but didnt know if it was any good or not
Old May 15, 2006 | 03:03 PM
Car: 92 Camaro RS
Engine: 5.0L
yeah its super thick, around here its like 7-8 bucks a bottle, add the 1 quart of it with 4 quarts of the motor oil you use at every oil change...i used 10-30 and a quart of lucas in my trans am, and if for some reason i couldnt get lucas, i ran 20w-50. they say you can run more lucas but as you will see, the stuff is thick as jelly, shouldnt need more then a qt. thinkin i might start runnin it in my 2.8 with the quaker state high mileage 10w-30 i run.
every oil addative ive used has sucked and caused more issues, except lucas, i like it.
Last edited by 1988CamaroSC; May 15, 2006 at 03:05 PM. Reason: Automerged Doublepost
Old May 15, 2006 | 03:07 PM
Car: 84' Trans Am
ill try it next oil change, sounds like good stuff. if it stops that noise its worth every penny.
Old May 15, 2006 | 03:15 PM
Car: 92 Camaro RS
Engine: 5.0L
it didnt totally stop it, it masked it for me ( quiet it down ), it only knocked at super low rpms after i ran the lucas, but it definately IMO kept it from getting worse, and let me tell you 14-18 year old kid with that car, i totally spanked it every mile i drove it.
Old May 15, 2006 | 03:18 PM
Car: 84' Trans Am
lol, mine only makes the noise when it warms up and makes it around 2000rpms some im going to try that stuff, cuz i want the car to last a few more years.
Old May 15, 2006 | 03:38 PM
sgapen's Avatar
knocking motor
ive had cars last for years knocking and then ive seen them go out the next day too so its a crapshoot really but personally i want a good motor so i can go on long cruises without the worry of oh no is it going to die in bfe!!
Old May 15, 2006 | 07:39 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Exactly right, it could be 5 minutes, it could be 5 years, you don't know until it blows up.
Old May 15, 2006 | 07:42 PM
Car: 84' Trans Am
its not a bad knock if it is, but if it goes out it gives me an excuse to buy a new motor and go through everything.
Old May 15, 2006 | 07:44 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Keep this in thought though.. I personnally will never use the stuff, If its as thicker then honey, then it will most likely stick to the lifters/what ever else, and not flow back down too keep everything else from getting lubed...
Old May 15, 2006 | 07:47 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
i would just drive it till it dies then when and if it dies then think about it but i would not worry to much about it
Old May 16, 2006 | 11:04 AM
Car: 92 Camaro RS
Engine: 5.0L
its actually about as thick as honey, good comparison, but if you only use one quart it doesnt stay that way obvisouly because it mixes in very well with the 10 30, and when i change it after 2500 miles, it comes out just as quick as just the 10 30 alone. its not like were running 5 quarts of lucas in the pig...every mechanic around here reccommened it to me for my bird.
Old May 16, 2006 | 11:31 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
I still wont use it in my engines... Ive talked to people at my local car club that have used it, Their PERFECT motors took a dump after they put in one quart of that stuff, (all in old 60's and 70's camaros,stangs,cudas, ect ect)
Old May 16, 2006 | 11:45 AM
Car: 92 Camaro RS
Engine: 5.0L
84 trigger, what kind of oil are you running now, if its just a regular conventional oil, id think about going to valvoline max life, or quaker state high mileage, (red containers) these too seem to help my motors, my daily driver is a 1995 toyota camry i bought from a grandma january 2005 with 60k, now i got 90k and at 3000-3500 mile oil changes, it still is fairly gold in color, not black at all, i also run it in my maro, with the same outcome, and i did run it in my t/a before i sold it. ove rall its good stuff...
Old May 16, 2006 | 11:48 AM
Car: 84' Trans Am
im running some vavoline 10w30, i heard of this royal purple oil thats supose to be good. Im going to try lucus first than try the purple. its says to give u more horsepower plus better fuel economy.
Old May 21, 2006 | 08:01 PM
Car: 84' Trans Am
this week i bought some of the lucas oil treatment, it works like a charm, it made that noise quiet down a bit. thanx 4 the help.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
