starting and idle problems
Old May 16, 2006 | 03:30 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
my 83 camaro when its cold will start hard i have to pump the gas like 4 to 5 times to get it to turn over then when it idles it idles at like 1500-2000 RPMs and wont kick down after about 4 to 5 mins of idleing it will kick down and i did notice that when i first get it started and its idleing like that for about 1 min or less i put it into gear and it dies then i start it back up and put it in gear again and it dont die. But when its wormed up it runs and idles just fine and does not die i have no clue what is making this happen if anyone might know what is making this happen let me know. thanks
Old May 16, 2006 | 03:32 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
carb.
Old May 16, 2006 | 03:34 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Originally Posted by 84 Trigger
carb.
could it be the fuel pump?
Old May 16, 2006 | 03:36 PM
Car: 84' Trans Am
there only $20, doesnt hurt to try.
Old May 16, 2006 | 09:41 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
make sure that the choke is working correctly. If I recall, it's an electric choke on those and sometimes the spring inside either breaks or isn't hooked up right.
Take off the air cleaner when the car is cold and pump the gas pedal once, this should allow the choke plate to close fully, if it doesn't, you'll have to find out why.
If it does close, let the car idle on fast idle for a few minutes, still with the air cleaner off, and see if the choke opens, once again, if it doesn't...why?
Old May 17, 2006 | 09:23 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
My '84 does the same thing - always has even when new. It won't kick down until the electric choke lets it. Because these cars only have 105-110 HP new (probably under 100 HP on a worn engine) the car is pretty much undriveable until the choke is off. One thing you could try is get a choke cover kit and drilling out the rivets on the choke cover so that you can adjust the tension. This should let it kick down sooner.
Old May 17, 2006 | 09:40 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Do you happen to hear any sort of whistling sound? A vacuum leak will behave similar to that, if it happens in conjunction with a carb that's running on the rich side (such as when first cranking and warming up)
Old May 17, 2006 | 02:58 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
i have not herd any whistling nosie ill prob check it out this weekend it drives me nuts it only does it when it sits for a day if i start it up and wait till the rpms go down to like 500 and it worms up it wont do that again cuse iv been trying stuff out and i started it up and waited till the rpms went down and when it went down i turned it off and let it sit for like 4 or 5 hours come back and it starts and idles fine i just dont get it
Old May 17, 2006 | 06:36 PM
Car: 84' Trans Am
rebuild the carb or buy a reman. thats ur best bet. or try adjusting the throttle on the carb.
Old May 17, 2006 | 07:29 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Check out the choke like I following the instructions I gave you. Getting the carb rebuilt might not solve the problem anyway because after that's done, you'll have to adjust the choke anyway. And if that's the problem, then you'll have paid $200+ to have the carb rebuilt and end up with the exact same problem.
Old May 17, 2006 | 07:40 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
ill check that out first cuse thats what im thinking it could be
Old May 17, 2006 | 07:43 PM
Car: 84' Trans Am
could it be caused by a gas leak? anyone know?
Old May 17, 2006 | 07:46 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
i know i am leaking a lil bit of gas
Old May 17, 2006 | 11:02 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
It could, but the leak would have to be into the intake manifold, out onto it wouldn't change anything but your effective milage. The pump should be able to keep the bowl full short of a complete leak, and if it's leaking that much, you probably shouldn't be starting it to figure out a bogging problem.
Old May 18, 2006 | 02:43 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
thanks for the help guys
Old May 21, 2006 | 08:05 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
me and my friend checked it today it was working what else could it be i think ill just rebulid the carb i dont think that was ever rebuit so thats prob why
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
killer777
Aug 8, 2015 02:47 PM
