2.8 aluminum heads on a 3.1?
Old Jun 8, 2006 | 02:39 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
Transmission: MB1 5spd
I have a 2.8L engine I pulled out of an 88 FWD Grand Prix. The intake is entirely different, but seems to mate to the heads in the same place. Does anyone know if they are interchangeable with the Camaro 3.1?
I have another thread, concerning the hesitation problem, and I'm wondering if air is getting past the valve guides. I had the original cast iron heads vacuum checked (they checked out OK), but didn't do a valve job. I'm just wondering if when the valve is opened, the stem clearance changes, and lets air in?
This car is a daily driver, and I can't afford the down time in doing a valve job on the existing heads. I could rebuild the aluminum heads, and swap them out, if they will fit.
Anyone know?
Thanks,
Bob
Old Jun 8, 2006 | 03:27 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
The heads will fit, but you'll need to put the intake on backwards, so the throttle body faces forward. You'll need the 2.8's tb, intake, and pistons as well if you want to run those heads......
Old Jun 8, 2006 | 04:05 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
I can't use the intake from the 3.1? Why would I need 2.8 pistons? Valve indentations?
Old Jun 8, 2006 | 04:08 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
search FWD heads, there are a few threads on this. the # 6 intake runner is to far back to use a distributor, you would need to use a custom dizzy or a ignition with a crank trigger, the combustion chamber on fwd heads is much smaller than the iron heads, you need the fwd pistons to compensate or you'll have VERY high compression
Old Jun 8, 2006 | 05:41 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
No good?
WOW, I didn't think there was actually a physical difference in the heads. So if the #6 intake is too far back, the RWD manifold wouldn't even fit. I figured the combustion chamber would be a LITTLE smaller, and I may gain some compression, but you're saying they used dished pistons on the FWD, so I really struck out!!
Thanks for the input!!
Bob
Old Jun 8, 2006 | 06:10 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
not to bust your ball but there are hundreds of 6cyls in the yards go get a set and rebuild them
Old Jun 8, 2006 | 06:22 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
Yeah, so I've heard, thanks.......
Old Jun 8, 2006 | 07:00 PM
Car: 1986 Firebird
yea, the iron heads have a 54 cc combustion chamber and the alum. have like a 26cc, that would put you at around 14:1 compression, so ive heard
Old Jun 9, 2006 | 11:56 AM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
pics of heads
yeah, Six Shooter posted a couple of pics in a thread I searched for, they OBVIOUSLY will not fit, thanks for the referral........
Old Jun 12, 2006 | 06:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Well.... They'll fit, you just need to change other parts to use them. Which IMO very worth the effort.
Old Jun 13, 2006 | 02:38 PM
'91TealRS's Avatar
Car: 91TealRS
Engine: 3.1L
They will?
I saw your pics of the aluminum head mounted on a 3.1 (or was that a 2.8?) next to a cast iron head on the other bank. It looks like the edge of the head would have to be machined to get the valve cover on.
Why would you recommend it? I would need different pistons also, right?
Old Jun 13, 2006 | 07:46 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok now this has got intresting,.,.somtimes ppl say one thing and others have diff expiriences.,now i feel like i have to know how much extra hp we talking about here?
Old Jun 15, 2006 | 03:59 AM
Yes it would be best to use the FWD pistons....
You will also need to use the inatke and a few other items, also swapping to a DIS ignition is a must,
There is a thread abuot using 3400 heads. I believe it was authored by 94Camaro.
The top end swap would be essentially the same, but will recommend skipping the genII and early gen III top end and go for the 3400/ 2000+ 3100 top end, much higher gains.
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
