After Market Cam Owners, Step In
Old Jun 17, 2006 | 01:08 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Mainly interested in owners ot the MTC-5 cam, but all aftermarket cam discussion is ok.
MTC-5 Owners, can you get a steady vac reading on your engine? Or does this cam have to much overlap that it will cause a bouncy reading like you have a leak?
All other cam owners, post your cam and if you can/cant get a steady reading.
Old Jun 17, 2006 | 07:57 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Well I don't have the MTC-5 cam but I do have the compcam 240H. I brought the kit with the tc and lifters and have no complaints. Gas mileage is a little better and the pep is ok. I get good vac readings also and it sounds good with the catback. Not a racer but its good for a daily driver which mines has turned out to be since its so much fun to drive.
Old Jun 18, 2006 | 07:46 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if i can get ahold of a vacuum gauge, ill let ya know. im back at school so most of my stuff is at home. are you having problems w/ yours dale?
Old Jun 18, 2006 | 08:37 AM
Dale's Avatar
Engine: 350 S-TPI
I still have a few little glitches. My gauge bounces a bit. My dad says its the cam with to much overlap. IIRC, the first cam that lasted 100 miles gave me a steady vac. So before I start to rip all this crap apart, I want to know from someone else.
Old Jun 18, 2006 | 03:15 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Well I do have an aftermarket cam but it's in a 350, with 224/230* @.050" in an engine with only 8.3:1 CR which is too low for it and I have fluctuating vacuum, 12-13.5" Hg. I don't have any vacuum leaks at the intake and frankly I don't worry about it, it does not affect anything.
What is the concern you have over this fluctuating reading? Are you just bugged by it, or is it causing actual problems?
Old Jun 18, 2006 | 04:19 PM
Dale's Avatar
Engine: 350 S-TPI
Yes, I have a few issues.
Old Jun 18, 2006 | 05:39 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what readings are you getting?
Old Jun 18, 2006 | 08:42 PM
Dale's Avatar
Engine: 350 S-TPI
I forget, its been a few days since I hooked it up.
I recall the first MTC-5 I had, had more pep then this one. Also, at first throttle I get a "hickup" then it runs. TPS is set properly.
Didnt get a chance to scan it this weekend.
Old Jul 11, 2006 | 07:33 PM
Dale's Avatar
Engine: 350 S-TPI
Dave or Doward, were you able to verify this for me?
Nothing on the outside of my engine is causing this. First cam I belive it was steady, this one is twitching like a crackhead w/o a fix.
Old Jul 11, 2006 | 07:41 PM
drdave88's Avatar
Engine: 6.0L
i havent been able to get ahold of my gauge, and probably wont for a couple weeks yet. sorry man.
GTAman
Mar 15, 2019 11:40 AM
deracer
Apr 11, 2016 12:04 AM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
