1995 3.4 firebird please help
Old Jul 15, 2006 | 05:25 PM
cw-hcr's Avatar
idols way to high, and looks like oil is driping out of the throttle body, i just had it rebuilt less than 90 days ago thanks guys
Old Jul 15, 2006 | 06:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I wonder if they intalled the correct PCV valve.
Old Jul 15, 2006 | 06:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Idle is set by the ecm, and you can not adjust that.
Oil in the TB? Excessive blowback, pvc wrong, gasket leaking.
If it was rebuilt 90 days ago, I'd take it back and complain.
Old Jul 15, 2006 | 07:07 PM
cw-hcr's Avatar
thanks ill try pcv what can i do about fast idol
Old Jul 15, 2006 | 07:47 PM
Dale's Avatar
Engine: 350 S-TPI
Like I said, idel is controlled via the pcm.
If its stuck fast, something is leaking (vac leak), jammed, not hooked up right.
Take it back!!!!!!!
Old Jul 15, 2006 | 08:01 PM
cw-hcr's Avatar
they said it was fine when i got the car back , fix it yourself you messed it up . {ran good for awhile, thanks bud
Old Jul 15, 2006 | 08:13 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
That's why I get everything with warranty... it's worth it. I have (on my trans) 12000, 12 month warranty... for the rebuild kit, pump, and shell... Everything else I get is from O'Reilly's and almost all is Lifetime, therefore; if it breaks, I don't shell the same cash out twice.
Also, I wouldn't do business w/ those guys again... They have crappy customer service. If it indeed is the PCV Valve, and it messes up more stuff, you can take them to court for it :P
Old Jul 15, 2006 | 09:10 PM
Dale's Avatar
Engine: 350 S-TPI
Bull ****, it should have come with a warranty.
I would for sure put the word out on that company. Shotty Biz=FTL.
Old Jul 15, 2006 | 11:45 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
if the pcv valve is stuck open it could allow enough air in with the throttle closed and iac at minimum to make the idle higher than it should be. oil could also be splashed up from the rockers and sucked in through the open pcv valve. thats actually about your only chance of getting oil in the throttle body, so i would say pcv is definitly a culprit. replace both valves, they're like $3 a pop.
or for a free check, disconnect the pcv from the tb, and plug the hole(in the tb, DONT PLUG THE PCV LINE), if you get the hole(s) in the tb fully plugged the idle should lower(although the iac counts are probably messed up because of the pcv) or at least change from what it was with the pcv hooked up. if so, replace the pcv stuff and you'll probably have to disconnect the battery and have the computer relearn the idle.
Old Jul 16, 2006 | 12:07 PM
cw-hcr's Avatar
thank you changed pcv and idol control valve it help it but still i bit to high but with ac. on its fine
Old Jul 16, 2006 | 01:35 PM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
How does the idle respond when AC is turned on and the compressor is running?
Old Jul 16, 2006 | 01:46 PM
cw-hcr's Avatar
it fine with it on
Old Jul 16, 2006 | 07:49 PM
cw-hcr's Avatar
the hoter it gets the faster it idols 2000 rpm in park ,and the valves rattle under a load, i pluged the vaccum from the air duct that goes to the valve cover [not the pcv ] it idols good like that but valves rattle
it may need to be set on fire lol
Dwayne614
Sep 28, 2015 08:33 AM
jtwoods4
Sep 3, 2015 05:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
