Is the 2.8L an interference engine?
Old Aug 21, 2006 | 12:48 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Very quick and easy question. Are our 2.8L V6 engines an interference engine? So if the timing chain were to break for any reason would the pistons be able to slap the valves?
Old Aug 21, 2006 | 09:02 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
No.
Old Aug 21, 2006 | 07:14 PM
JoshDT91's Avatar
Engine: 2.8L V6
Sweet I love that, thanks.
Old Aug 21, 2006 | 10:12 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
are you sure that's a no? i could be wrong but i would think its possible
Old Aug 21, 2006 | 10:26 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
unless you have an ultra high lift cam and heads that have been shaved to bare minimum, there is no possible way for the pistons to contact the valves on a 660 motor. There is too much clearance to be an issue. Ask me how I know...lol.
Old Aug 22, 2006 | 04:05 PM
Car: 91 Camaro
not even with a broken timing chain like he said? like, if a piston comes to TDC and a valve is open (obviously at the wrong time because of a broken timing chain), they won't contact each other?
Old Aug 22, 2006 | 04:10 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
no, if you take the timing chain off and roll the crank over (i have done that) nothing touches anywhere, it spins free, well till you hit a combustion stroke, lol.
Old Aug 23, 2006 | 12:29 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Nope, that's exactly how I know. I was driving one day, got on it hard, shifted into 3rd and the chain snapped right around 4000 rpm. Tore the front apart, slapped in a new chain and gears, started and has been fine since. Over 25K miles now on this chain.
Old Aug 23, 2006 | 03:40 PM
Car: 91 Camaro
ok, that seems a little surprising to me but if you all have done that stuff...guess you're right! However, I'd be scarred to try that with my cam!
Old Aug 23, 2006 | 03:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think the only 2.8's that were interference engines are the Gen II motors (FWD, aluminum head, splayed valves, heart-shaped combustion chambers)...
Old Aug 23, 2006 | 11:27 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Yeah, with a no tso stock cam like what I've heard you're running, it'd be a little scary. I don't know the exact clearence numbers, but I think there's enough that even with a radical cam in there you'd be ok.
Now, I don't know what kind of valvetrain you have, but I think you'd have to be running special valve springs and have over .750" of valve lift.
Old Aug 24, 2006 | 08:37 PM
Car: 91 Camaro
I've got domed pistons in it, too. with everything "in line", i've got over .125" clearance between the valves and pistons but I don't imagine I'd have that if something out of the ordinary happened.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
BurlyChev
Aug 16, 2015 09:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
