Help!:I want to gut out my smog?!!
Old Sep 24, 2006 | 09:42 PM
GoldenDrako's Avatar
I have read some threads that mention you can gut out your smog pump. But peps I've talked to say you can't gut out and just use the pulley assembly. That it will destroy it. I've got a 92 RS 3.1. Once I open the smog will it be common sense to gut out and reassemble to use as just a pulley? And do i need to disconnect the hoses and cap them after i gut out the smog? And the biggest question is will it have any ill effects on the any systems? Thanks...I'm a newbie glad i found this site And it rocks....best place for any info you might need and some that you never thought of!!!
Old Sep 25, 2006 | 08:36 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
when i got rid of my smog pump, i also swapped in my 3.4. i got rid of the lines going to the exhaust manifold. you can delete all the hoses and lines and all that by a screw in the vacuum line and getting plugs in the exhaust manifolds, or getting pacesetter headers which require the delete of those anyway. for the life of me i can not remember where the big vacuum hoses from the pump go to or what i did, but i know they are non-existant anymore anywehre on the car.
Old Sep 25, 2006 | 10:07 PM
You say you got rid of your smog pump...how? you removed it entirely? I have a serpintine belt so i thought i must gut out the smog pump to have the same belt routing...if you have better idea please tell me..and belt size if you know for the 3.1. thanks
Old Sep 26, 2006 | 12:08 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I got rid of the smog pump and run a shorter belt. I did have to build a custom alt bracket out of the old smog pump bracket.
Attached Thumbnails Help!:I want to gut out my smog?!!-engine5.jpg
Old Sep 26, 2006 | 01:22 AM
is it possible to gut out the smog pump? i have heard both yes and no...would like to do the easiest option...how does your car run now with it removed? gas milage and power?
Old Sep 26, 2006 | 02:09 AM
RSFreak's Avatar
I don't know about gutting it, though I can't imagine the parasitic drag would be much less if gutted. I didn't notice any gains in performance or change in mileage. I did get a less cluttered engine bay however! Of course I haven't had to pass the sniffer test yet either!
Old Sep 26, 2006 | 05:18 AM
drdave88's Avatar
Engine: 6.0L
ive never heard of gutting it. i just got rid of mine and got a shorter belt, no modifications needed. 88s came with or w/o smog pump so i guess thats why i could just ditch it. but id think the easiest way would be to just remove it, rather than taking it off, gutting it (if possible) and putting it back together.
Old Dec 3, 2006 | 02:32 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
if they came out without the smog pumps how did they pass emissions or the sniffer
Old Dec 3, 2006 | 10:14 AM
drdave88's Avatar
Engine: 6.0L
that one i cant tell you. im not sure what was different on the cars without it and the ones with.
Old Dec 3, 2006 | 01:53 PM
firstfirebird's Avatar
RSFreak, what size belt did you use?
If I just eliminate my smog pump it seems like the belt will rub itself when going aroud the alternator...
Help!:I want to gut out my smog?!!-beltrouting.jpg
Last edited by firstfirebird; Dec 3, 2006 at 01:56 PM. Reason: saw how it was re-routed
Old Dec 3, 2006 | 02:13 PM
Actually answered my own questions, thanx for the pic!
jaridjohn
Oct 5, 2015 07:01 AM
wstephan96
Sep 25, 2015 04:28 PM
