GROUP PURCHASE : TURBO KITS
Old Sep 25, 2006 | 03:20 PM
daves12secV6's Avatar
here it is guys
u get
turbo = t04e stage 3 57 trim .63/.50 (upgradable to a t-61)
bov = choice of greddy or blitz style - greddy comes in choice of color
fmic = fmic all aluminum 2.5 or 3.0 inlet/outlet
wastegate = hks style 40 mm wastegate with 3.63 psi spring
boost controller = manual ball and spring type
couplers = all reinforced couplers needed for piping
downpipe= 3.0 inch downpipe (retians cat converter) options for cereamic or hi temp coatings add $ ( to be determined)
oil feed lines and adapters = -3 an lines
includes new ypipe
and all turbo piping (painted ur color choice) poweder coating
this will not include oil return lines or injectors or fmu due to the adjustability of the system,injector and fmu needs will vary from person to person
parts can be upgraded for an aditional cost depending on ur needs
price for group purchase is 2,400$'s must have 5 orders
Old Sep 25, 2006 | 06:05 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Hey Dave.
I thought about it, and it would be pretty easy for me to mount the battery tray over on the passenger side. Now, the vapor canister will not necessarily be mounted on the drivers side (replacing the battery), as I already removed the air conditioning unit, and might be able to mount it in the fender (where the electric antenna is mounted, that general area), as there is plenty of room, as well as opening to route the required vacuum lines. I thought about simply tossing it, but if I can retain it, why not...
I already embellished my excitement regarding this kit, as it was very well designed. For those who didn't get a chance to see, the car idled flawlessy the moment the engine ignited. No hesitation, nada! Will be running 15-psi on the street, as the Walbro has already been installed awhile back, just need bigger injectors, as well as an AFPR. I'd still like to hear some feedback about RBob's EBL (in reference to tuning), as opposed to burning chips, repeatedly to get it just right...
Anyways, four more purchases needed.
Old Sep 25, 2006 | 06:38 PM
u dont necisarily need to burn chips.u can get an emulator from moates.net.think of it as turning the chip into a flash chip.and u can upload a new tune while the car is running.its call ostrich.if i wasnt on my pos tunning laptop id hunt down the link but on the main moates page just click were it say emulators
Old Sep 25, 2006 | 06:53 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
Definately interested in this kit... Sign me up? But does the battery HAVE to be relocated? Do i have the option of keeping the A/C?
Old Sep 25, 2006 | 07:15 PM
camaros dont have to relocate the battery,unless its on the drivers side,as far as i know all camaros have the battery on the passenger side,and only the firebirds had the batt on the left side.u can keep the ac,i found it easier to install the kit with the ac lines removed,but u dont have to
Old Sep 25, 2006 | 07:35 PM
Bad-Newz's Avatar
??? I have both and '88 camaro 2.8 and a 91 camaro 3.1 and the battery is on the left in both of em...
Old Sep 25, 2006 | 07:46 PM
both cars have the battery on the drivers side?
Old Sep 25, 2006 | 07:50 PM
Bad-Newz's Avatar
yup... could this be a canadian thing?
Old Sep 25, 2006 | 07:59 PM
yeah it could be,ive never seen a v6 camaro with the batt on the drivers side,its not a big deal to move the battery,but i can always just reverse the routing of the charge pipes.its really not a big deal
but it is somethng i would need to know when u place an order for the kit
Old Sep 25, 2006 | 08:03 PM
Bad-Newz's Avatar
Assuming thats the way the canadian cars came... If u could reverse the pipes that would be great. BTW, Dave do u run headers on your car? And if so any problems regarding them and the turbo piping?
Old Sep 25, 2006 | 08:05 PM
nope still using manifold.but pacesetter headers will work with the kit
Old Sep 25, 2006 | 08:19 PM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
my 92 RS with the 3.1 has a battery on the drivers side
Old Sep 25, 2006 | 08:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
my battery (camaro) is on the passenger side, its an 88.
Old Sep 25, 2006 | 08:37 PM
yeah no big deal u just need to tell me which side the battery is on when u place ur order.
Old Sep 25, 2006 | 08:42 PM
drdave88's Avatar
Engine: 6.0L
no dave, what you need to tell me is that i can get this turbo kit for about the price my fiance thinks is.......................... a good deal, lol. trust me i tried to rationalize w/ her about it, you know how it goes.
Old Sep 25, 2006 | 08:44 PM
lol lmao, i had to convince mine that 2,400 was a great price to sell them for for the group buy,she wanted me to get 2,800 each for this
Old Sep 25, 2006 | 08:47 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
my battery is on the driver's side, too
Old Sep 25, 2006 | 09:15 PM
LMAO. I guess mine would have responded the same way, but even she was very impressed with the kit. I tell ya Dave (Dr.), when I caught up with it at the track, I never expected to see what I did. I mean, it looks as if it literally belongs in there when you see it up close. The creativity is very prevalent to the trained eye, and the simplicity of it makes it so damn unreal...
I explained to her that the amount of time it would of taken me to figure out the right way of routing of the all the piping (I barely have enough time do anything other than work anymore), as well as all the little things that always seem to pop up when designing your own setup, I'd be saving myself a lot of headaches, as well as the expense of any possible mistakes (welding etc.), in the long run. I was so damn impressed with his kit, because it is exactly the way I would have wanted it, the right way...
Old Sep 25, 2006 | 10:05 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I thought all 3.1 batteries were on the driver side?
Old Sep 25, 2006 | 10:33 PM
thge car i pulled my 3.1 had the batt on the passenger side
Old Sep 25, 2006 | 11:44 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
my 85 bird came w/batt on drivers side, fwiw
Old Sep 26, 2006 | 12:15 AM
RSFreak's Avatar
OK, does all turbo piping include the exhaust manifold or did I miss something?
EDIT: OK, I was just looking at your pics on the How-To thread. It looks like the turbo isn't bolted directly to the exhaust manifold like I thought. Interesting...
Old Sep 26, 2006 | 12:34 AM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
If you hit your 5 person mark, and then later on you open up your store. Will you be raising the price of this setup? If so that's okay, money well deserved, good job and luck on the setup and starting of your company. Time for me to start Saving .
Old Sep 26, 2006 | 12:46 AM
yes cost on the base kit will goto 2,800
i will still be making these after the group buy,the group buy is just to get some out to members of tgo, i already have 2 orders for kits outside this site,and a custom twin turbo setup for one of my friends blazers
Old Sep 26, 2006 | 03:32 AM
Car: 1991 Firebird
Engine: 3.1L V6
Not bad at all, i'd take $2800 on something proven to work, over a kit like BBSDesigns $4000+ turbo kit.
Old Sep 26, 2006 | 10:50 AM
Bad-Newz's Avatar
Im plannign on installing an aluminum driveshaft in my car. I hear alot of mixed reviews about them though. Some say they cant handle much power some say they can... I'm sure this kit won't pose a problem with the shaft.. rite? Any warranties or anyhting like that to be included (not to sound like one of those people, lol)
Old Sep 26, 2006 | 04:54 PM
AtomicZebra's Avatar
Wow sounds great! The only thing is I have the 2.8, will this kit work with it? If so I probably won't do my engine swap, unless this kit will fit itpower anyone? Well I also have the automatic transmission and with the way I have beaten on it I dont think it could take the power, so do you have any suggestions on a new transmission? (Preferably a 5 speed) Also my buddy has a spare T3/T4 turbo laying around that he'll give me a good deal on so would you be able to take the turbo out? One more question, what other parts do we need to buy to have it in and running? Any special air filter or lines? Thanks alot and good luck with your future turbo kits.
Old Sep 26, 2006 | 06:12 PM
es arent something i thought about,though each turbo and wastegate comes with a warrenty of 1 year when i get them so i can include that,other then that theres nothing really to break
i personally dont like alum drive shafts,but yeah it should hold up,id be more worried about the u joints then the shaft itself,warrenti
yes this will fit the 2.8/3.1 will even fit a 3.4 in a 3rdgen.the only thing u would need to buy would be yes the air filter,the oil return lines(im not inclusing these cause u need to put the fitting in the oil pan urself,so if i made up lines and u installed the fitting in the wrong spot,the lines wouldnt fit anyway,and i am not including injectors(since this kit is adjustable in the amount of boost it could run,well if i gave u injectors to run 7 psi but u wanna run 12 psi there useless to u anyway.)
Old Sep 26, 2006 | 06:31 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I'd sure love to turbo my RS, but lets just say the moderator on this board that owes me $950 or my parts can answer why it hasn't happend.
Old Sep 26, 2006 | 06:34 PM
i happened to hear about an incident this morning so im pretty sure i know what ur talking about
Old Sep 26, 2006 | 07:59 PM
firstfirebird's Avatar
Dave, glad to se your up and running with this! Asked you before about marketing them. I'm designing a twin turbo set up for V6 3gens, even have a bud that works @ a CNC shop! Plan is to make 2 manifolds that the turbo will mount directly them, from there to the bottom of a intercooler (two 2 1/2" inlets one 3" on top) then directly into the manifold. I stole the intercooler position from an '87 GN one of my customers has (9300 orig. mi. how cool) but i don't know about the fan on the harm. balancer.
Any how thanks for the input and I'm glad to see your sticky STICK!
One more question though, Have you had any problems with detonation yet running on pump gas?
Old Sep 26, 2006 | 08:10 PM
not at all though whenever i have the boost above 14psi ive run a mixture of pumpgas and 104 octane race gas.scratch that i did have detonation problems a 2 times in the dead of summer when it was like 103* out running 10 psi.after about an haalf hour of sitting in traffic and then getting on it i had a lil bit of drtonation.though it was a combination of engine temps around 200* and the fact the intercooler/piping was heat soaked
Old Sep 26, 2006 | 10:13 PM
Did you use dished pistons, flat tops, etc?
Old Sep 26, 2006 | 11:10 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
What kind of horse power is this gonna put out, like 7psi at what and 9 or 10 psi at what....and if i would want to run lets say, 9 or 10 psi...what should be done to the motor??? thanks
Old Sep 27, 2006 | 12:15 AM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
^^^^^ please read sticky
Old Sep 27, 2006 | 06:49 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Im 100% in. But like I said in the other thread I would want to buy the intake, headers, and turbo. So I dont know if that would qualify me for the group purchase. Also would payment be due before or after it is built? Thanks
Old Sep 27, 2006 | 07:43 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
what sticky???
Old Sep 27, 2006 | 10:02 AM
blackcrow64's Avatar
Car: 92 Firebird - 97 Talon TSi AWD
Engine: Firebird: 3.1L - Talon: 2.0L
Transmission: Firebird: 700r4
Originally Posted by jak2908
what sticky???
This sticky...
https://www.thirdgen.org/forums/v6/3...ing-turbo.html
Old Sep 27, 2006 | 04:17 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
that thread told me nothing about how much power it puts out i must be blind???
Old Sep 28, 2006 | 12:44 AM
No, it doesn't say how much power it'll put out because that would depend on too many factors. Engine condition, amount of boost you run, how you tune it, etc. The sticky was to give you a breakdown of the process and what things you will need to do it. He listed no such needs for internal upgrades on a basic setup running 7psi. That was to answer your question about what should be done to the motor to support this setup.
Old Sep 28, 2006 | 01:41 AM
^^^^ true, and jak, theres noway someone can tell you how your motor will run.....to mant factors, from daytime temps...to elevation...to motor. its different for everyone. not to sound mean, but someone asks the same question at least every other day. g/l.
Old Sep 28, 2006 | 02:45 AM
  #42
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Thread closed penting administrative authorization or decision to delete.
Terrell351
Jun 13, 2021 01:13 PM
NORTz89
May 20, 2020 03:51 PM
Magman
Sep 13, 2015 08:43 AM
BlackphantomZ28
Aug 31, 2015 11:19 AM
hectre13
Aug 26, 2015 08:17 AM
