3.1, 3.8
Old Oct 16, 2006 | 08:48 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
3.1, 3.8
Hi,
I have a 1992 camaro 3.1 v6, automatic trannsmission. I was wondering since a v8 wont work with my kind of tranny would a 3.8 v6 bolt up?..thanks.
Old Oct 16, 2006 | 09:34 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
no it wont bolt right up, youd be better off swapping an LT1 than trying a 3800 swap. your best "bang for the buck" is the 3.4 swap, bottom line. try a search on different engine swaps and youll find that out. and a 3.4 will bolt up to your trans, a 2.8/3.1/3.4 are the only ones that will bolt up.
Old Oct 16, 2006 | 09:53 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Ok i got a question. From what i read from searching computer chips arent good for anything and a waste of money? Is there noticable power difference? If there worth the money will this work good in a 1992 camaro 3.1 v6? Is it possible to add more aftermarket performace parts after installing a chip? Hypertech ThermoMaster Computer Chips: HYP-122332 - summitracing.com
Old Oct 16, 2006 | 11:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if it's an early buick 3.8, it wont' bolt up. IF it's a 3800 II, that engine block has a 60* tranny bolt pattern. Your newer yr dash electronics would fit nicely w/the II wiring. Just have to make sure you get the engien harness along with 95.5~97 are good, as the 97 pcm has the same pin outs as the earlier yrs, but is programable.
As far as the aftermarket parts for the 3.1, make a plan as to what your goal is, what parts you need, and what order you cain afford them. There is a sticky, or was, on the aftermarket parts for the 2.8/3.1 engiens.
Old Oct 17, 2006 | 07:02 AM
drdave88's Avatar
Engine: 6.0L
if youre going to get a chip, do your mods and then get a custom chip burned. the stage 1 & 2 chips arent really worth anything, a few guys have even said they noticed a decrease in performance after putting them in.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Elephantismo
Feb 13, 2019 12:51 AM
neilb
Oct 4, 2018 12:36 AM
cking99
Sep 22, 2015 11:33 AM
