Head Type
Old Oct 28, 2006 | 07:12 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Head Type
Does the 87 Firebird 2.8 have aluminum heads or cast iron
Old Oct 28, 2006 | 09:57 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
ALL F-bodys that have the 60* v6 block IE RWD 2.8/3.1/3.4 ALL have the Iron heads. Only FWD 60* V6s came with the alum heads. Using the Alum heads requires A DIS ignition or a custom intake to clear the Dist hole. to use the Alum heads you must also swap the pistons to the FWD versions for each of the different displacements to keep Compression ratios down because the FWD head has a much smaller chamber.
Old Oct 28, 2006 | 11:17 PM
kelham's Avatar
k thanks alot... plan on rebuilding next week but im looking at different kits
colton_carlson
Mar 8, 2019 12:21 PM
z28guy134
Sep 1, 2015 11:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
bdads
Aug 24, 2015 06:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
